  3800sc w/F23 swap
3800sc w/F23 swap by Grizz54
Started on: 05-06-2015 10:02 PM
Replies: 6 (394 views)
Last post by: Grizz54 on 05-11-2015 12:23 AM
Grizz54
Report this Post05-06-2015 10:02 PM Click Here to See the Profile for Grizz54Send a Private Message to Grizz54Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm finally getting around to doing my 3800sc/F23 swap. I haven't been able to find the link to the thread for clutch, spacer, axles, etc. It's going in an 87 SE. Can someone point me to the correct link?
FIEROFLYER
Total ratings: 180
Report this Post05-07-2015 09:05 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock axles still work use a Camaro flywheel machined down to .840 get a good clutch and use the HTOB spacer .250 thick, and an adapter for the clutch hydraulic line. Then make up some mounts and shifter brackets and that is it for the tranny portion of this swap
Grizz54
Report this Post05-07-2015 10:53 PM Click Here to See the Profile for Grizz54Send a Private Message to Grizz54Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info. I bought a flywheel and had it machined. I seem to remember that the Spec II clutch was the most desirable choice. Have mounts made. Where can I get the spacer? I also remember something about having to have shift cables made up. Is this correct? To avoid asking a lot more already answered questions, I would still like to get some links to threads. Thanks again.
"To err is human" Nuff Said!
ericjon262
Report this Post05-09-2015 12:13 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
make sure to get the flywheel balanced.
akademikjeanius
Report this Post05-09-2015 02:33 PM Click Here to See the Profile for akademikjeaniusSend a Private Message to akademikjeaniusEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/Forum2/HTML/133081.html
https://www.fiero.nl/forum/Forum1/HTML/087296.html
hnthomps
Total ratings: 50
Report this Post05-10-2015 07:43 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want an opinion on clutches, I have the SPEC Stage II on a turbo 3.4 set up and it works pretty well. However, for the 3800 SC Series II or III I would suggest using a SPEC Stage 3 plus. It is very streetable and holds the extra hp better than the SPEC Stage II (IMHO). I do have this clutch on a 3800 SC Series II engine and will eventually install it on my 3800 SC Series III engine when the current one dies.
Nelson
Grizz54
Report this Post05-11-2015 12:23 AM Click Here to See the Profile for Grizz54Send a Private Message to Grizz54Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks to everyone for the info. I did have the flywheel balanced when I had it machined. The links are what I needed to answer some questions. I am swapping from auto to manual (ugh). But I have a manual car to rob parts from. I will need a 5 spd shifter though, right? Don't have one of those.
