  Console shift pod restoration
Console shift pod restoration by kpaxton
Started on: 05-05-2015 08:51 PM
Replies: 9 (386 views)
Last post by: kpaxton on 05-05-2015 10:35 PM
kpaxton
Report this Post05-05-2015 08:51 PM Click Here to See the Profile for kpaxtonSend a Private Message to kpaxtonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am experimenting with a new way to restore a shift pod. I am covering the frame with 1/4" balsa wood and the shaping it to fit the vinyl. I have removed all the foam from the vinyl to do this and don't know if it will work. Once I have the wood shaped to fit the vinyl I am going to coat it with fiberglass resin.[img]This images is larger than 153600 bytes. Click to view. [img]This images is larger than 153600 bytes. Click to view.
kpaxton
Report this Post05-05-2015 08:53 PM Click Here to See the Profile for kpaxtonSend a Private Message to kpaxtonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The beginning of the process.[img]This images is larger than 153600 bytes. Click to view.
kpaxton
Report this Post05-05-2015 08:54 PM Click Here to See the Profile for kpaxtonSend a Private Message to kpaxtonEdit/Delete MessageReply w/QuoteDirect Link to This Post
kpaxton
Member since Apr 2015
[img]<a href="http://imgur.com/ljNmU9x"><img src="http://i.imgur.com/ljNmU9x.jpg" title="source: imgur.com" /></a>[/img]
kpaxton
Report this Post05-05-2015 08:57 PM Click Here to See the Profile for kpaxtonSend a Private Message to kpaxtonEdit/Delete MessageReply w/QuoteDirect Link to This Post
kpaxton
[img]<a href="http://imgur.com/naEwElI"><img src="http://i.imgur.com/naEwElI.jpg" title="source: imgur.com" /></a>[/img]
[This message has been edited by kpaxton (edited 05-05-2015).]
kpaxton
Report this Post05-05-2015 08:59 PM Click Here to See the Profile for kpaxtonSend a Private Message to kpaxtonEdit/Delete MessageReply w/QuoteDirect Link to This Post
kpaxton
[img]<a href="http://imgur.com/CsS5UsN"><img src="http://i.imgur.com/CsS5UsN.jpg" title="source: imgur.com" /></a>[/img]
Mike Gonzalez
Total ratings: 130
Report this Post05-05-2015 09:02 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should use PIP or nobody is going to bother and try to make those broken links work.
kpaxton
Report this Post05-05-2015 09:37 PM Click Here to See the Profile for kpaxtonSend a Private Message to kpaxtonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I gave up on PIP. Doesn't like my photos.
Mike Gonzalez
Total ratings: 130
Report this Post05-05-2015 09:54 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://imageresizer.codeplex.com/ Is your friend using PIP, if PIP doesnt like the size, right click the image in the PIP browser, resize, and post the re-sized image.
On a plus, a couple of your links worked this time for me.
seajai
Total ratings: 51
Report this Post05-05-2015 10:32 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fixed your pics for you. Pictures can also be resized using Microsoft Paint. PIP is quite easy to use once you get the hang of it, you just need to make sure you resize your pics. Also, use the "Preview" tab before you submit your post to make sure it's going to look like you want it to.
kpaxton
Report this Post05-05-2015 10:35 PM Click Here to See the Profile for kpaxtonSend a Private Message to kpaxtonEdit/Delete MessageReply w/QuoteDirect Link to This Post
thank you for fixing my pics. I have made numerous attempts and I just can't get it to work. That's why I post using the other way.
