  Exhaust q for the 3800 crowd
Exhaust q for the 3800 crowd by Dave E Bouy
Started on: 05-04-2015 12:33 PM
Replies: 10 (856 views)
Last post by: ericjon262 on 05-06-2015 01:08 PM
Dave E Bouy
Report this Post05-04-2015 12:33 PM Click Here to See the Profile for Dave E BouySend a Private Message to Dave E BouyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi all. I'm doing some 3800 upgrades for a friend. We will be install an XP can shaft with all the valve springs and retainers and timing chain upgraded as well. Adding a short stack intercooler and a smaller pulley. Ant remember the pulley size off the top of my head. Can we continue to use the stock exhaust manifolds? There's not much budget available for anything too fancy. Whaddaya think?
Thanks
DF
nosrac
Total ratings: 50
Report this Post05-04-2015 01:01 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
DF
Yes, but I would recommend a plog.
Report this Post05-04-2015 09:33 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
No doubt that the P-Log flows far better that the stock front manifold. We had a couple here and decided not to use them but I kept one just for modification and possible future use. When installed, the PLOGS sit very close to the A/C compressor. I am uncomfortable with that fit- too much header heat near the compressor for my taste. Anyone else have these concerns with the ZZ P-Log?
mitchjl22
Report this Post05-05-2015 03:12 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mine WILL NOT FIT WITH THE AC COMPRESSOR
-Mitch
Report this Post05-05-2015 09:19 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
-Mitch
We did not experience this when we tried fitting the PLOG but did find that it sat about 1/16" away from the top of the compressor. That was when the engine was on a stand off the car. I believe that the PLOG was designed for the Grand prix 3800 so if you have an engine for another application fitment issues may happen. The assumption is that different year 3800s and different applications affect the fitment. Our experience was disappointing as you have a good flowing product with installation issues.
Squishyxout
Report this Post05-05-2015 06:01 PM Click Here to See the Profile for SquishyxoutSend a Private Message to SquishyxoutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Who needs A/C ?????
Report this Post05-05-2015 07:05 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Squishyxout:
Who needs A/C ?????
Us folks who live at the lower latitudes like it, plus if I didn't have A/C my wife would not ride with me. You only lose horsepower when its turned on.
Tuna Helper
Report this Post05-06-2015 08:15 AM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
What do you so for the rear manifold? I'd like to put my shift cables back in stock position and have some actual exhaust.
Dave E Bouy
Report this Post05-06-2015 08:47 AM Click Here to See the Profile for Dave E BouySend a Private Message to Dave E BouyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok guys thanks. Plog it is
DF
FIEROFLYER
Total ratings: 180
Report this Post05-06-2015 10:42 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
If you don't mind a little extra work I have liked using the Mustang manifolds in the past for modified engines as well as for 4 speed manual swaps to get rid of the upper crossover cleaning things up quite a bit and keeping heat away from the throttle body
ericjon262
Report this Post05-06-2015 01:08 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
the PLog is a very simple design, it wouldn't be hard at all to replicate if you have the time. which would allow you to also correct any a/c clearance issues.
"The day I tried to live, I stole a thousand beggars' change and gave it to the rich."
