| | | quote | Originally posted by 1MohrFiero:
Are these a problem with Grand AM/Beretta brakes? |
First, its only an issue on the 88's because their front lower a-arm is closer to the backside of the rotor.
Second, its only an issue if the upgraded rotors are deeper than the stock 88 rotors, because that is what moves the rotor closer to the front lower a-arm.
The grand am rotors are the same depth as the 88's, but they wont fit over the flange on the 88 front wheel bearings unless you turn them down. Several in years past have modified their bearings to allow the use of the grand am rotors vs. the stock 88 Fiero rotors because they were cheaper.
