| quote | Originally posted by Jim_Martin29:
I open the throttle and the engine hesitates, like it’s taking a breath, then it tries to accelerate back.
When I do close the throttle the car surges forward slightly.
Both symptoms are classic weak fuel pump or restricted fuel supply system.
You can have good pressure at idle & revving the engine but if you leave the gauge connected and drive the car the pressure will drop when the
symptoms occur, not enough fuel volume to keep the pressure up. You back off the gas, higher volume of fuel not needed now, pressure goes up &
the car surges forward for a second.
Could be a bad pump (can't supply enough volume under a load to keep the pressure up), plugged fuel filter or other restriction in the fuel line.
Whenever I test drive a car with a low power problem but no misfires the first thing I do is accelerate & back off the gas a little - if I get a power
surge it's 99% a fuel problem, usually the pump.
If not, 2nd check is exhaust backpressure. Your 3psi is slightly high but shouldn't cause your problems.
