  brakes get better when hot
brakes get better when hot by tshark
Started on: 04-28-2015 09:50 AM
Replies: 5 (118 views)
Last post by: theogre on 04-28-2015 10:44 AM
tshark
Total ratings: 68
Report this Post04-28-2015 09:50 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero Vampire
Report this Post04-28-2015 09:56 AM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have stock or performance pads, or do you know?
tshark
Total ratings: 68
Report this Post04-28-2015 10:11 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
tebailey
Report this Post04-28-2015 10:27 AM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like some one installed performance pads, they are made to work better when hot.
tshark
Total ratings: 68
Report this Post04-28-2015 10:28 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post04-28-2015 10:44 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
"My '88s brakes start out weak. If I drive for perhaps 20 minutes, the brakes become awesome."
Running on highway etc won't affect Vacuum problem to/at/in the booster.
Running on highway can/will heat the pads. Worse if the pads are dragging a bit. (If your pads are dragging because of caliper problem, that can/will cause brake fade.)
My guess you have "racing" pads that needs more heat to work.
Normal, like any "cheap" pads from AZ etc, and Premium pads, like Wanger TQ, pads won't do this.
