does anyone know know the wiring for the 97 fiero headlamp motors because the book only shows how to hook it up if the connectors are together and the person that owned the car be for be cut them all off im left with a bunch of hanging wires i have 3 red a black and a blue then a green and a gray coming off the actual motor
Though this info would be useful to someone it not me my mistake the fiero is an 86 I always forget because I was told 87 when I bought it if you can still help that would be awesome
I would guess you're looking at cut wires a few inches from the motors themselves. The 86 system uses 3 relays, 2 of which are connected right next to the motors. It's sad to say many misinformed fiero owners cut wires for headlight motors to remove essential parts in effort to re-wire them with "custom toggle switches". The end result is rare relays get lost, and the specific 2-piece connectors that the early system used to connect the relays are discarded with them, all while never fixing the system. I suggest finding a parts/donor car and swapping in a complete uncut headlight harness (look for any '84 to '86 fiero as a donor). And expect to still need troubleshooting. I did this for both of my systems and still had an underlying issue. But a perfect wiring harness was still great peace of mind. Also, the blue wire from the motors have their own single-wire connector, (this wire controls the headlights closing when turned off). This is my recommendation, though you can attempt to splice in correct parts if you have the nerve to wreck a different car's wiring. Once the wiring is fixed, the troubleshooting page posted earlier is a godsend. Good luck!
[url=https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-xfp1/t31.0-8/905982_943207795699738_6465452890441772455_o.jpg?efg=eyJpIjoidCJ9][/url] so this is what I got the green and gray come off both motors. I don't know what any of the other wires are for. other then that the blue hook to the motor some where some how
The pigtail in the pic, plugs into one half of the motor actuator relay. The motor itself has a nearly identical connector at the end of the green and gray wires that fits into the other half of the same relay. (The two connectors look like one whole connector when both are plugged in). The blue wire will have it's own connector and will plug into the harness' blue plug right there in the picture. The relay gets mounted to the headlight assembly via two 7mm screws, you'll likely see two white-ish nylon inserts where these screws go into. It sounds like you're missing the relays and the motor's side pigtail connector. More pics of the motors should verify.
These are both motors. Their isn't a blue wire coming off either motor. Nor is their a relay near them. Only one mounted on the side wall on drivers side
You have a bit of a problem. You have an '84 to '86 car and headlight harness. But you have '87 to '88 headlight motors. And probably the whole headlight buckets from 87 to 88. Where you go from here is up to you. 84 to 86 is generation 1. 87 to 88 is generation 2. Most people will recommend that you locate the wiring harness and control module for generation 2 and swap it into your car. They claim gen 2 is better (faster motors, quieter, and supposedly more reliable against failure). But good luck locating a parts car. You can still revert back to gen 1 motors and repair your wiring, and locate some relays. But again, hard to find parts, especially the relays. As far as I know, you can not make your current components work as they sit.
Well I guess I'm on the hunt for parts. I'll go which ever direction I find first thanks for the help. And at least I have found what I have to do to fix them finally
You may want to go over this setup with a fine-tooth comb. If you have a way to talk to previous owners, it might help. I have personally had this kind of problem with both my '85 trans am and my '86 fiero. I opted to buy complete generation 1 headlight harnesses in both instances, and deal with locating the relays as needed. I've been lucky and both cars have functional systems now. If you go this route, get the complete wiring harness from a donor car, it will have 3 relays. And grab both motors along with the 3 long mounting screws that each motor bolts on with (you will have 6 long bolts total). The swap of wiring is somewhat straightforward, but I wound up removing the hood to route it all. If you decide to keep your current gen 2 motors, you need the complete wiring harness that includes the headlight module that gets mounted inside of the driver side fender (big pain to reach).
Seems like no matter which way I go. Their is a lot of work to be done. But not sure I want to mess with the module. Forgot all about that for the gen 2 system probably Ganna go back to gen 1
Someone stuck a gen 2 module in my fiero along with the harness, but not the motors. It was a cluster***. So I do have a spare module (and heavily cut up harness) if you would want to try. I would advise against the wiring part since I cut large amounts off lol. Your easiest route is to locate gen 1 motors/bolts, cut the relays and the wires with sufficient length at the right spots, and splice them into your existing wiring. Lazy way, it makes me cringe to think about, but it's your car and your call. I may have some donor wiring left to help get ya started. The blue wire connector is available from the fiero store, but I forget if it's the male or female half. Let me know if by a decide ya need help. If you do decide to cut, after finding a local donor car, just please take your time figuring out where to cut the wires. I know what it's like to get confused over working with missing parts.
If you want rebuilt Gen 1 motors I have them on eBay. I will take your Gen 2 motors in as cores and give another $25 discount for the module if it is good. I may also have some good used relays with wire pigtail if you need.
