  Gen 2 Headlight Ctrl Module locale
Gen 2 Headlight Ctrl Module locale by triads
Started on: 04-27-2015 05:11 PM
Replies: 5 (168 views)
Last post by: triads on 04-29-2015 09:36 AM
triads
Report this Post04-27-2015 05:11 PM Click Here to See the Profile for triadsSend a Private Message to triadsEdit/Delete MessageReply w/QuoteDirect Link to This Post
As most of us know, the Gen 2 control module on the 87 & 88 are located in the drivers side wheel well.. For those of us that upgraded from Gen 1 to Gen 2 don't have the luxury of a place to stash this module.. My question is, for those that did a gen 1 to gen 2 swap, where did you place your module? I just put mine under the drivers headlamp, which in hind site was a bad move as I now know that the module is not water tight, and water is not the modules friend.
Any ideas would be helpful...
mafv8
Report this Post04-27-2015 05:43 PM Click Here to See the Profile for mafv8Send a Private Message to mafv8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I put mine on the front trunk area bulkhead, in front/below the brake master cylinder assembly.
Cajun
Report this Post04-28-2015 10:09 PM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put mine in the same locations as the 87/88 Fiero's, driver side wheel well.
Report this Post04-28-2015 10:35 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
W/o cutting wires etc.... I think Wires should reach inside front "trunk" area.
Just make sure wires don't rub any hole.
Is a bit of pain but can use OE location.
The module and Metric Pack connectors are water resistant not water proof.
Many things won't last long when soaked.
[This message has been edited by theogre (edited 04-28-2015).]
steve308
Total ratings: 58
Report this Post04-29-2015 08:40 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
I put mine in the left headlight bucket after applying a liberal amount of silicon sealant to the area of the connectors. Car has only been driven in the rain once-Carlisle last year- and I've had no issues with the lights with the module in this location.
triads
Report this Post04-29-2015 09:36 AM Click Here to See the Profile for triadsSend a Private Message to triadsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the ideas.. i'll try the trunk option first..
