  Confirmation on Testing Ignition Coil Results
Confirmation on Testing Ignition Coil Results by LiftHatch
Started on: 04-26-2015 03:46 PM
Replies: 1 (177 views)
Last post by: Gall757 on 04-26-2015 04:17 PM
LiftHatch
Report this Post04-26-2015 03:46 PM Click Here to See the Profile for LiftHatchSend a Private Message to LiftHatchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was testing my ignition coil to see if it is faulty using a multimeter. While testing for resistance, I set the dial at 20k reading and it measured step 1 and step 3 at 8.5 ohms (I'm guessing 85,000 ohms?) I turned the dial down to 200 and measured step 2 as 0.5 ohms (basically little to no resistance). Based on the description given in the picture, I think the ignition coil is faulty because step 1 should have been "out of limit" or infinite. I need someone to confirm if this is correct.
Report this Post04-26-2015 04:17 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes... your Step 1 is not good.....get a new coil.
