  3800 shifter auto modification
3800 shifter auto modification by johnguzman1212
Started on: 04-26-2015 03:56 AM
Replies: 2 (183 views)
Last post by: johnguzman1212 on 04-27-2015 10:56 AM
johnguzman1212
Report this Post04-26-2015 03:56 AM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used search function but only found an Isuzu and paddle and Manuel stuff. My question I have an 87 fiero with a HD auto trans from a 97 Riviera ...the cable looks like its going to reach even with my lambo stretch . Will I be needing to do any heavy modifications on brackets? Or just a little bending?
Total ratings: 205
Report this Post04-26-2015 09:23 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The shifter needs no mods, and already has the detents for the four speed auto. You will need to modify the shift arm (1 5/8" from pin to CL of the shaft opening), reclock the arm slightly and modify the shift cable bracket on the transmission.
[This message has been edited by olejoedad (edited 04-26-2015).]
johnguzman1212
Report this Post04-27-2015 10:56 AM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you very much my friend
