  Wiring help ASAP please
Wiring help ASAP please by Jayfelt
Started on: 04-24-2015 04:41 PM
Replies: 9 (195 views)
Last post by: Jayfelt on 04-25-2015 05:02 PM
Jayfelt
Report this Post04-24-2015 04:41 PM Click Here to See the Profile for JayfeltSend a Private Message to JayfeltEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just about done with my transmission swap from auto to 5 speed manual. Just confused on what exactly im doing with this switch on the transmission. Not sure on if im cutting it or rewiring it.
FYI: I am converting the automatic harness.
Mike Gonzalez
Total ratings: 130
Report this Post04-24-2015 05:03 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
If that is the backup light switch they need to go to c500 C1 and E1.
Jayfelt
Report this Post04-24-2015 05:46 PM Click Here to See the Profile for JayfeltSend a Private Message to JayfeltEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it is and thank you!
Also to confirm the only wiring i need to do for the swap is Clutch safety switch and add longer wiring for the VSS plug and the reverse switch correct?
Mike Gonzalez
Total ratings: 130
Report this Post04-24-2015 07:44 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe so, I have never done the swap without a engine/PCM swap at the same time.
Total ratings: 290
Report this Post04-24-2015 08:41 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might want to remove the extra wires to the AT switch AND to the torque converter lock up, but you can also just cut and cap them if you wish.
Report this Post04-25-2015 09:55 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since you are reusing the Auto harness, in addition to the clutch switch at the pedal, you have to splice the thick Yellow and Purple wires together at the automatic connector plug (wide, thin, black connector). The reverse light wires are also in this same connector, so they will need to be cut and spliced into the reverse switch at the transmission. Then shorten the VSS wires (or just coil them up), and wrap up the TCC connector (not used).
Jayfelt
Report this Post04-25-2015 10:06 AM Click Here to See the Profile for JayfeltSend a Private Message to JayfeltEdit/Delete MessageReply w/QuoteDirect Link to This Post
Witch wires are the reverse wires on the connector and are the reverse switch wires interchangeable? They are both the same color so cant tell and am unseure
Report this Post04-25-2015 10:40 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The reverse light wires at the connector are blue and green and thin (16-18ga).
The switch at the transmission ball detent contact switch and should be internally isolated (not self grounding), so it shouldn't matter how the wires are connected. If you want to verify the proper connection sequence, get a Chilton/Haynes/Helm manual for the 85-88 Fiero and look at the wiring diagrams for the 4cyl/Isuzu transmission. It should show the Green and Blue wires going to the Isuzu connector and show the pin location (A & B or 1 & 2) and the connectors normally have this designation molded into the connector. Unfortunately all my manuals are buried in storage (and 300 mile from me right now) or I would look it up for you.
Total ratings: 290
Report this Post04-25-2015 02:25 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's just a switch so it doesn't make a difference.
Jayfelt
Report this Post04-25-2015 05:02 PM Click Here to See the Profile for JayfeltSend a Private Message to JayfeltEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you very much guys. Electrical is my week point with any car. Thanks again for taking your time and trying to guide me threw this.
