  Where does this wire go?
Where does this wire go? by parkerjnc
Started on: 04-22-2015 02:28 PM
Replies: 4 (121 views)
Last post by: parkerjnc on 04-22-2015 02:41 PM
parkerjnc
Report this Post04-22-2015 02:28 PM Click Here to See the Profile for parkerjncSend a Private Message to parkerjncEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is embarrassing. Replaced a water pump on my 88GT 2.8L. While I had everything out I also repaired the rusted and corroded battery tray.
Work got in the way and some time passed.
Now I've gotten everything reinstalled and am putting the battery back in. I have a small pointed bolt that I had labeled "negative ground wire" which I'm sure goes to the pigtail lead coming off the negative battery cable. I just can't for the life of me remember where the bolt screws into.
Any hints?
parkerjnc
[- 88GT 2.8L -]
Domtech
Report this Post04-22-2015 02:33 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe on my car that goes to a hole by the side of the strut tower, next to the battery tray.
FIEROPHREK
Total ratings: 137
Report this Post04-22-2015 02:37 PM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
It should go on the battery tray. The part that angles down as it goes back the shock tower.
12.3 is faster than a 13.2
parkerjnc
Report this Post04-22-2015 02:38 PM Click Here to See the Profile for parkerjncSend a Private Message to parkerjncEdit/Delete MessageReply w/QuoteDirect Link to This Post
You don't mean the small hole where the screw goes that is holding the battery shield?
parkerjnc
Report this Post04-22-2015 02:41 PM Click Here to See the Profile for parkerjncSend a Private Message to parkerjncEdit/Delete MessageReply w/QuoteDirect Link to This Post
parkerjnc
Member since Mar 2015
Went and checked again and found it. Had some loose insulation from the shock tower covering it up. Thanks for the help!
