  Headlight motor
Headlight motor by aktadracer
Started on: 04-22-2015 12:54 PM
Replies: 7 (676 views)
Last post by: theogre on 04-23-2015 11:31 AM
aktadracer
Report this Post04-22-2015 12:54 PM Click Here to See the Profile for aktadracerClick Here to visit aktadracer's HomePageSend a Private Message to aktadracerEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of my headlights tries to open, moves then drops back down, the manual "knob" still spins for about 5 seconds both direction, when opening and when I shut the lights off, since the motor is obviously running what is the issue and what is the fix?
coltonandrew
Report this Post04-22-2015 12:59 PM Click Here to See the Profile for coltonandrewSend a Private Message to coltonandrewEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know anything about the headlight motor, but do you maybe have a bad ground?the control module for it might be broekn as well.
My drivers side doesnt even engage anymore, it burnt out in the rain a few night ago. I have to crank it by hand. Its 103 cranks to either open or close it haha
coltonandrew
Report this Post04-22-2015 01:11 PM Click Here to See the Profile for coltonandrewSend a Private Message to coltonandrewEdit/Delete MessageReply w/QuoteDirect Link to This Post
coltonandrew
Member since Mar 2015
Actually it sounds like a stripped gear now that I think about it. It catches in the friction, but with no teeth or a loose gear, it can't really move the entire weight of the head lamp
aktadracer
Report this Post04-22-2015 01:11 PM Click Here to See the Profile for aktadracerClick Here to visit aktadracer's HomePageSend a Private Message to aktadracerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well the motor runs but the light doesn't rise so it's getting power just not engaging to rise
Report this Post04-22-2015 01:33 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post04-22-2015 01:39 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
This sounds like an 84-86 motor, so i'll base my comments on that.
If you can open the hood, grab the headlight and lift, causing the motor to finish the lift, then you have a gear with 3 or 4 teeth stripped off at the bottom end of travel.
If the headlight won't raise, even with manual help and the motor continues to run, the drive plate for the gear has probably come loose from the shaft. This is an unusual happening unless the motor has been previously rebuilt. That can be determined by screws and nuts holding the two halve of the motor case together. If it still has the rivets, it's possible that the fingers on the drive plate have broken off due to the disintegration of the bump stops.
It would be a good idea to disconnect the single blue wire with the barrel connector and raise and lower the motor manually by sticking a ball point pen or small screwdriver into the dimple in the knob and spinning it. By using this method, you can more rapidly raise or lower the light than you can by using your fingers.
Motor rebuild service using Rodney's metal gears are $30 labor for each motor.
Cost of gears and return shipping are added without markup. Workmanship guaranteed for 1 year.
Email or PM me if you are interested.
aktadracer
Report this Post04-23-2015 11:13 AM Click Here to See the Profile for aktadracerClick Here to visit aktadracer's HomePageSend a Private Message to aktadracerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually mine is an 87, does this make a difference?
Report this Post04-23-2015 11:31 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes.
See my Cave, Gen 2 HL Motor
