  Any recommended aftermarket Fuel Gauge Sending Units to use on stock f/p module?
Any recommended aftermarket Fuel Gauge Sending Units to use on stock f/p module? by hdryder
Started on: 04-19-2015 03:44 PM
Replies: 3 (158 views)
Last post by: johnguzman1212 on 04-20-2015 03:54 AM
hdryder
Report this Post04-19-2015 03:44 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are there any aftermarket Fuel Gauge Sending Units, with potentiometer, that work well and can be added fairly easily to the stock Fiero fuel pump module assembly?
Report this Post04-19-2015 04:13 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is pretty old, but still may work.
https://www.fiero.nl/forum/A...090219-2-078597.html
[This message has been edited by Gall757 (edited 04-19-2015).]
IXSLR8
Report this Post04-19-2015 04:15 PM Click Here to See the Profile for IXSLR8Send a Private Message to IXSLR8Edit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/Forum2/HTML/134771.html
As long as you get one that has the same ohm reading range your good to go. I have an aftermarket one with the ball float on the end. Its fussy work but is worth it in the end if you want an accurate fuel gage reading.
johnguzman1212
Report this Post04-20-2015 03:54 AM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a inteltronix but it's digital ebay 50 bucks says it's for gm and works perfect
