  Pushing duke to the limits
Pushing duke to the limits by Slammed
Started on: 04-16-2015 08:01 PM
Replies: 31 (1164 views)
Last post by: Slammed on 07-04-2015 09:18 PM
Slammed
Total ratings: 79
Report this Post04-16-2015 08:01 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a thread going about headwork on this S10 I'm building for a guy but it is going in a different direction so I'm starting a new one
'89 S10 motor
Update: New head! Mucho work done. 9.5 secon 0-60! This is an automatic. Huge jump in power
I enlarged the ports 8.5mm vertically and 3mm in both the intake and head. Stock 1.72 valves. The throats have been enlarged to 1.54" The throat is actually bigger than the 3800SC heads I have sitting here.
But, this is where things have gone past head work. We just received the forged rods and pistons. 6" 2.00 rods and +5cc 1.565 comp height pistons. This is a very low mileage motor and will keep the standard 4" bore. Should give us just about 10:1 ratio
Headwork
Ideas, thoughts, and comments all welcome.
[This message has been edited by Slammed (edited 06-18-2015).]
Total ratings: 463
Report this Post04-16-2015 08:11 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting. I've got an SD4 that I'm about to bolt the 2V version of that manifold onto. (Removed the Dellortos to give them a proper rebuild. Am installing a 2V Holley to make the car driveable while I screw with the others.)
The ports in the head are already huge. I may match port the intake if it needs it.
Slammed
Total ratings: 79
Report this Post04-17-2015 04:13 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would have been nice to start with an SD4. AFAIK the S10 motor hasn't been built like this before so it'll be interesting to see what happens
The rods/pistons were bought in sets of 8. If he blows it, we'll just do another and throw this head on it with a thicker gasket. We are going with a custom copper HG at .010 right now
solotwo
Total ratings: 62
Report this Post04-17-2015 11:12 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you putting that into a Fiero?
Slammed
Total ratings: 79
Report this Post04-18-2015 12:53 AM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
For now it is in the S-10
He picked up a very low mile 84 that will be the recipient after a summer of racing
RWDPLZ
Total ratings: 305
Report this Post04-18-2015 02:44 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Needs some theme music:
https://www.youtube.com/watch?v=9D-QD_HIfjA
One of the mods I was looking into before I got my job and lost all my free time, was swapping in an ECU from an early 90's S10.
Slammed
Total ratings: 79
Report this Post04-21-2015 04:03 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
When cutting the new seat angles for the exhaust valves, cracks came through on two of the ports
Locknstitch here we come
Slammed
Total ratings: 79
Report this Post06-08-2015 07:37 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
We started over with another head. I put hardened seats in the exhaust and installed new guides
Wow. I don't know how else to explain it. The difference is night and day. The only comparison I can make is to my '84 4 speed that was rebuilt last year
This is an automatic S10 and it laughs at my little Fiero. Mind you, this is on a stock tune, stock throttle body, factory cam, with the original (clogged) cat from 1989. Also, this is a tired bottom end. Compression is only 150 and the ridge on the cylinder walls would need at least .030 to remove it. It pulls right to 5000
We will dyno it after the tune, TB bore, cam and exhaust.
[This message has been edited by Slammed (edited 06-08-2015).]
Slammed
Total ratings: 79
Report this Post06-09-2015 07:40 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ran it around a good amount today after swapping out the cat for a straight pipe and clearing out the muffler
Consistent 9.5 second 0-60
I'm excited to see what happens with the other mods we have planned.
Slammed
Total ratings: 79
Report this Post06-12-2015 02:03 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have burned a couple chips now and driven it a couple hundred miles
Most dukes idle sort of rough and vibrate. We haven't installed a harmonic damper and the engine is sooo smooth. Sitting at 750rpm you can barely tell it's running. So little vibration. I've never seen headwork make such a huge difference on a vehicle. The power comes on immediately and turns right up to 5k no problem. Merging is a breeze and cruising at 75 uphill is no problem.
Report this Post06-12-2015 04:31 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Start building heads like these to sell to us Fiero folk.
Slammed
Total ratings: 79
Report this Post06-12-2015 05:33 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
That could definitely be arranged. Let's see what the dyno says and go from there
cebix
Report this Post06-13-2015 03:45 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
What fuel supply are you using? Is it carbed or injected? If injected then what TBI - the standard Rochester 300 or the newer 700? Any mods done to the fuel supply system?
Slammed
Total ratings: 79
Report this Post06-13-2015 04:29 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
700. Zero mods. Haven't hit max duty cycle on the injector and the wideband puts us at 13.2:1 at WOT
Report this Post06-13-2015 05:07 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting project and nice work. The last modified Duke that I recall was built about 12 years back by Neil and Dawn Kline (Racincouple) . Neils health issues caused the sale of the car and someone else in PA owns it now. It had a cam and SBC 10:1 pistons. The engine ran well provided extra power and for the time that they had it stayed together. I estimate that if your goal is 125 HP, the S10 block and crank should suffice.
Slammed
Total ratings: 79
Report this Post06-13-2015 05:13 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
We are past 125 already I'm sure of that. We'll be north of 160 before we are done with it. To compare, the 2.8 auto Fiero is a 9 second 0-60.
That is before the Eaton M62 goes on.
[This message has been edited by Slammed (edited 06-13-2015).]
cebix
Report this Post06-13-2015 05:26 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool man, wish you luck. Dukes are cool engines, simple, reliable, economical - a shame people hate them for their lack of power and their noise. Seems the power issues are solved! Did you calculate fuel consumption? Is the auto the stock THM-125C 3-speed?
EDIT: Just read that it's an S10 not a Fiero... what auto gearbox do you have though?
[This message has been edited by cebix (edited 06-13-2015).]
Slammed
Total ratings: 79
Report this Post06-13-2015 05:46 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
4l60. I'm uploading a couple videos right now.
Almost through half a tank. It's looking like it went from 24ish to 27, but won't know til it's gone. These aren't the best gas gauges
Report this Post06-14-2015 03:45 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those horsepower numbers are very impressive but I would suggest being very cautious putting boost in that engine. The Duke doesn't have the best record for reliability with boost. Thin block walls and lightweight connecting rods are a limitation. I know of one Duke "Hi-Tech" turbo install formerly owned by Steve V (BV Motorsports) and it did work but IIRC the boost was kept to 4-5 psi. Estimated Horsepower was about 135. AFAIK, the car has changed hands twice after Steve had it and still exists.
Slammed
Total ratings: 79
Report this Post06-14-2015 04:41 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
We have another motor being built right now. Forged rods and pistons with a cryogenically treated crankshaft, and a 1pc 3.0 rotating assembly as backup. In '98 we had a turbo duke in a buggy pushing 140 to the wheels. Stock internals and we beat the absolute crap out of that thing
For how many years now has everyone been talking about weak duke, this that, with how many pictures of actual failures of motors built by reputable builders? To give you an idea, I have bored several iron dukes to .060 with no cylinder failures. The whole thing is blown way out of proportion. Add to that, out of the dozens of dukes we have had in the machine shop over the years, the most common thing is rods. I have never once seen a broken crank. Now, most of the people aren't out hotrodding these anyway, but it's something to point out
[This message has been edited by Slammed (edited 06-14-2015).]
Slammed
Total ratings: 79
Report this Post06-18-2015 01:39 AM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I spent the last two days using the truck for parts runs, and from home to the shop(90 miles round trip) both days
I got 29.5mpg this tank! I'd say about 75% was highway
Report this Post06-18-2015 10:28 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I enjoy your ambition.
cebix
Report this Post06-18-2015 04:00 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice MPG for the power, keep posting.
Slammed
Total ratings: 79
Report this Post06-18-2015 08:22 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post06-19-2015 10:12 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you mention what the rear diff is in the S10?
Slammed
Total ratings: 79
Report this Post06-19-2015 03:33 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
3:42
[This message has been edited by Slammed (edited 07-04-2015).]
Slammed
Total ratings: 79
Report this Post07-04-2015 09:56 AM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm starting on the MPFI next week
Maybe I should start a new thread for that
fierosound
Total ratings: 286
Report this Post07-04-2015 11:10 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
... out of the dozens of dukes we have had in the machine shop over the years, the most common thing is rods. I have never once seen a broken crank. Now, most of the people aren't out hotrodding these anyway, but it's something to point out.
Vanderley developed the head for the Pace Car/Super Duty engine. According to the SD4 Guide,
the head flows 80% more air out of the box (before any porting or other head work) than the stock Duke head.
It is common knowledge that the Duke engine fires were caused primarily by failing connecting rods.
They were crap pieces to start with and once the engine ran low on oil and seized, they would break.
The better flowing head will make the power, and aftermarket rods will keep it from breaking.
The Duke crank will have a limit on horsepower and RPM it can handle (SD4 crank RPM limit is 9,000)
Calgary time/temp
[This message has been edited by fierosound (edited 07-04-2015).]
Slammed
Total ratings: 79
Report this Post07-04-2015 11:14 AM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I forgot to post the flow numbers. At .500" lift we were at 193cfm. Damn good for those 1.72 valves
Formula88
Total ratings: 554
Report this Post07-04-2015 06:29 PM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looking forward to the final configuration dyno numbers.
It's neat to try new ways to make power, but I have to wonder how much it's going to cost to approach the power of a stock 3400 or 3800NA.
Report this Post07-04-2015 07:20 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The OP plans to add boost so we will have an opportunity to see if he is able to go beyond the power limitations of the Duke engine. My guess is 135HP at the flywheel and 100HP at the wheels is possible. . That would give the car 2.8L performance.
Slammed
Total ratings: 79
Report this Post07-04-2015 09:18 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think you both missed this is a customer car with an unlimited budget. 200bhp is the goal. Not done until we hit it
We have two motors that we are putting together right now. Both .030 over, 6.000" Eagle SIR I beams, Keith Black +5cc 1.565ch pistons and arp hardware. One is a stock nitrided and then cryo'd crank, all balanced. The other same internals, except 5.7 not 6.0 rods, but a 1 piece 3.0 crank, turned to 2.00 . Again nitrided and cryotreated. 135hp? Ha.
I posted it above, but I raced a buggy in 98 and 99 with a bone stock, new 93 turbo duke. 140whp and we beat the heck out of it
[This message has been edited by Slammed (edited 07-05-2015).]
