  Adjustable koni strut won't adjust.
Adjustable koni strut won't adjust. by Bridgetown
Started on: 04-13-2015 12:24 AM
Replies: 3 (193 views)
Last post by: fieroguru on 04-14-2015 11:25 AM
Bridgetown
Report this Post04-13-2015 12:24 AM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently added helper springs to my rear Koni coilovers (88) during the process of putting one of the struts back together I had some trouble getting the piston rod back up inside the rubber bushing. As I worked the piston up from underneath, I also pulled (gently I thought) up on the adjuster tab with a pair of pliers. I got it all back together fine, but when I went to check the adjustment of the strut, the adjuster just spins now. There doesn't seam to be a stop anymore in either direction. So... Am I missing something, or have I screwed my strut up somehow?
Bridgetown
Report this Post04-13-2015 02:37 PM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found a diagram of the rear konis.
http://www.koni.com/uploads...nitt_AundB_kl_06.gif
I can't see how pulling upward on the tab could damage it that badly?
If the j hook is broke, the shaft should be loose and probably come right out.
[This message has been edited by Bridgetown (edited 04-13-2015).]
Bridgetown
Report this Post04-14-2015 10:58 AM Click Here to See the Profile for BridgetownSend a Private Message to BridgetownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Report this Post04-14-2015 11:25 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would call KONI support and ask them about it.
