  3800 Swap
3800 Swap by jimcamboli
Started on: 04-11-2015 08:26 AM
Replies: 8 (340 views)
Last post by: 1fast2m4 on 04-17-2015 12:01 PM
jimcamboli
Report this Post04-11-2015 08:26 AM Click Here to See the Profile for jimcamboliSend a Private Message to jimcamboliEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alrighty,
I have an 86 SE and I'm really wanting to do a swap for a 3800 SC. I have never really done an engine swap before, so I'm a little new when it comes to this. What I need is a list of parts that I need and a cost estimate on things like the new supercharged motor, new manifolds, gaskets, mounts... etc. Basically, I need a list of everything I'd need and about how much it"d cost me out the door. Thanks guys.
Very Respectfully,
Mike
Report this Post04-11-2015 08:50 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/Forum2/HTML/123518.html
3800 Build Parts List
[This message has been edited by Gall757 (edited 04-11-2015).]
jimcamboli
Report this Post04-11-2015 09:14 AM Click Here to See the Profile for jimcamboliSend a Private Message to jimcamboliEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you!
Riddick85
Report this Post04-11-2015 09:23 AM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
It cost me around 2300 with buying a good motor from a junkyard and buying the swap parts from vendors here on the forum. Fierorog is great for mounts and flywheel if going manual. Fieroflyer and phondawgz do wiring harnesses
Curtisk1060
Report this Post04-12-2015 08:58 PM Click Here to See the Profile for Curtisk1060Send a Private Message to Curtisk1060Edit/Delete MessageReply w/QuoteDirect Link to This Post
I also like using FieroFreak00 custom fuel rails as they clean up the whole engine very nicely and make the fuel line hook-up a breeze. Contact Jason, he does great quality work!! Also, contact Ryan at Sinister performance to custom program your PCM, He is known as DarthFiero here on Pennock's. He can answer many technical questions you may have as well. Another great guy to work with!! Curtis
[This message has been edited by Curtisk1060 (edited 04-12-2015).]
zzzhuh
Report this Post04-12-2015 09:52 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another guy from Colorado?
You have a p.m.
Every fiero has a story, It's our job to keep that story alive.
Mike Gonzalez
Total ratings: 130
Report this Post04-12-2015 10:05 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
Woot!! Colorado !!
I saw someone linked a thread with my list of swap parts/mods, so I wont repost it here !
johnguzman1212
Report this Post04-16-2015 06:05 AM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
im almost done with mine I havnet hit 1000 yet but mine has a lambo kit so im doing extra stuff
1fast2m4
Report this Post04-17-2015 12:01 PM Click Here to See the Profile for 1fast2m4Send a Private Message to 1fast2m4Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can check out my build (link in sig) i just gathered over the counter parts and threw it all together in about a month.
I got my mounts from West coast fiero
I got my harness from Phonedawgs
I made my own pass side axle for the HD auto tans
I made a super simple single 3" exhaust
I re routed my Belts to delete the P/S pump and left the Alternator up high to keep things simple
The one thin I can't stress enough I probably spent over $1,000 at various auto parts stores for purely miscellaneous parts like hose, hose clamps, wire, CV boot straps, heat shrink tubing, fluids, filters, belts, bolts, paint there are so many little $2 or $4 things you need to button it all up.
1986 SE 3800SC/4t65eHD (12.871@104.96)
HX-40, FrozenBoost I/C, 80lb injectors & E85 Coming soon.....
