  Complete Vacuum Loss When Warm (Intermittent)
Complete Vacuum Loss When Warm (Intermittent) by LaFierte
Started on: 04-09-2015 12:34 AM
Replies: 39 (757 views)
Last post by: LaFierte on 04-13-2015 09:49 PM
LaFierte
Report this Post04-09-2015 12:34 AM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
My dad and I have been scratching our heads over this one for a while now... I have and 86GT with a 2.8L. When driving it seems to intermittently lose vacuum. The only thing it seems to be connected to is when the car is in closed loop (warmed up). We've checked all the vacuum line and components. They are all good. It is very odd because the vacuum actually goes to zero when driving and it's been getting worse. (Don't worry, I only take it out for test drives now to prevent further damage) I've checked/ tested or replaced the ICM, TPS, MAP sensor, egr valve, egr vacuum solenoid assembly, air charge sensor, fuel filter, oxygen sensor, and cap and rotor (not all for this problem just listing some stuff for a quicker response from people . ) two interesting, likely related things... The O2 sensor had a chunk missing out of it, the distributor cap had its center pin out of the middle of it on the inside and looked like it had been arcing. None of this solved the power/vacuum loss problem. I'm wondering... Could this be a plugged/melted Cat backing up the engine badly? It only has about 30kmiles on the cat.
Any ideas anyone? Hopefully you guys can save me some time, money, and heartache
Report this Post04-09-2015 12:37 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ummm... I've got to admit, I don't know what you mean. "Complete vacuum loss..."???
Does this mean you can't clean your carpets? Seriously though, you've lost me.
LaFierte
Report this Post04-09-2015 12:53 AM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
The engine uses vacuum to run... If I hook a vacuum gauge up to the engine and drive a little ways, the engine will intermittently lose all vacuum.
LaFierte
Report this Post04-09-2015 12:54 AM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
LaFierte
Member since Mar 2010
Honestly, I'm not sure how it is staying running with no vacuum at all... I'm not sure how it could run like that.
Report this Post04-09-2015 12:58 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I understand where the vacuum comes from and why it's required. I don't see how an engine can run with NO vacuum.
Very few of us drive with a vacuum gauge attached to our engines. What are the symptoms of low/no vacuum that you're experiencing?
[This message has been edited by Patrick (edited 04-09-2015).]
LaFierte
Report this Post04-09-2015 01:07 AM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't understand it either haha, that's why I'm on here. I attached the vacuum gauge and a fuel pressure gauge after having problems with intermittent power loss while driving in closed loop (I test drove it with the gauges attached, so did my dad. We took turns watching them since they were sticking out from where the decklid vents normally are). Fuel pressure was fine, nothing wrong with that system, I've sense checked everything just to be sure. But the vacuum gauge would go to 0 to 4 psi during these power losses. Really has me scratching my head.
[This message has been edited by LaFierte (edited 04-09-2015).]
Report this Post04-09-2015 01:14 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where do you have the vacuum gauge connected?
Sounds to me like you have the vacuum gauge connected to a port that has controlled vacuum... like something to do with the gas tank venting or EGR system or whatever. I'm just guessing here.
There's no way that the intake plenum itself or the throttle body sees no vacuum with a running engine.
LaFierte
Report this Post04-09-2015 01:22 AM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
On a tee, directly off the upper intake plenum. And I did try a second gauge just to make sure the first wasn't off. It read the same. Maybe my car is possessed? This no vacuum (or extremely little on some occasions) doesn't kill the engine, but it only lasts for a few seconds at a time, and of course I lose all horsepower then. Maybe the fact that the transmission is engaged keeps it running? I was thinking a melted cat because that would explain when it only happens when I'm driving it, and the vacuum loss too if it was backing up the exhaust.
Report this Post04-09-2015 01:44 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a plugged cat once on my '86 GT, but I didn't experience anything like what you're reporting. I found that I couldn't get the engine to rev over 2000 RPM or so.
I have since found out that a quick way to check for a plugged cat is to temporarily remove the o2 sensor. If the extreme back pressure is causing an issue, then removing the o2 sensor allows the pressure to escape. I haven't tried this myself. I'd be kind of afraid of where the hot exhaust gases would be aimed.
tebailey
Report this Post04-09-2015 08:33 AM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sticking valve could cause a temporary vacuum drop.
Report this Post04-09-2015 08:44 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bad ECU grounds (intermittent, such as a loose but) will also cause symptoms like you mention.
Vacuum is measured in Inches of Mercury (inHg), not PSI.....
LaFierte
Report this Post04-09-2015 10:01 AM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Patrick, I may have to look into that idea. Just one question on it, since this only seems to happen under load in closed loop would taking the oxygen sensor out through off the computer enough to cause problems while on a test drive?
And valve? Are you talking head valve? Or EGR? I replaced the egr valve with a brand new one, it didn't change the symptoms.
I've checked the gounds, they all seem good, not corroded at the connections, tight, and passed a continuity test. And yes vacuum can be measured in mm Hg, it can also be measured in PSI, Pascals, etc. All three of the ones at home here read in pounds. It just came down to what was available. From what I have read most of the people that have tested vacuum on here have done it in pounds, and have gotten around 15-19 pounds on average (from my reading on trying to solve this problem). I normally run at 17, but it drops to between 0 and 4 pounds under the conditions previously mentioned.
Report this Post04-09-2015 10:14 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The only way this could happen would be a very large intermittent vacuum leak, which sounds crazy......but possibly your brake booster hose is loose or cut, or the internals of the booster are damaged.
[This message has been edited by Gall757 (edited 04-09-2015).]
Riddick85
Report this Post04-09-2015 11:50 AM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just in case you didn't realize, when you push the throttle your vacuum will go near zero since are essentially creating a vacuum leak. That aside I would plug each component running from vacuum and see which is the problem. My guess is since it affects driveability so drastically, either brake booster as previously mentioned or you may have an IAC, idle air control, issue.
LaFierte
Report this Post04-09-2015 12:06 PM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
IAC has been checked. Swapped and reswapped back in when it didn't make a difference. Throttle position does not seem to matter. In fact it usually happens when I have my foot holding down the gas at a constant rate, not moving it now that you mention it. As far as the brake booster... My braking power is excellent. Can it still be the brake booster? I suppose I could plug the hose to it and test drive it carefully. Thank you for the ideas guys.
tebailey
Report this Post04-09-2015 12:27 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
When your vacuum drops do you pick-up an engine miss? Also any popping?
LaFierte
Report this Post04-09-2015 01:01 PM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I do. After a period of power loss and vacuum loss it pops load a few times and goes back to normal. Timing is on.
tebailey
Report this Post04-09-2015 01:11 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would have to say you have an intake valve sticking.
Report this Post04-09-2015 01:24 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
......valuable additional info......
LaFierte
Report this Post04-09-2015 02:05 PM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
What would fixing/checking the intake valves entail?
tebailey
Report this Post04-09-2015 02:21 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check everything under the valve covers first, if your lucky you'll find something there. If not it will mean pulling the heads.
Report this Post04-09-2015 02:27 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
This usually happens because an engine is running hot, or with low oil, and carbon deposits build up. Many shops have treatments that they can run through your intake....stuff like Seafoam, etc. and it could fix the problem. If not, you would need to take the valve covers off and look for something......maybe a weak/broken valve spring or one valve that is discolored.
LaFierte
Report this Post04-09-2015 11:35 PM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, so Before I go tearing into the heads and investigating for a sticking intake valve... I'm confused.... Since I'm only having the problem when it is hot and the car is under load like previously mentioned, wouldn't the intake valve idea also happen when the car isn't under load at least? (And when the car is cool as well?) I can still look, but I'm just confused on how that would work.
sardonyx247
Total ratings: 219
Report this Post04-10-2015 12:26 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
How to test for a plugged cat, with what you already have, a vac gauge
Hook up the vac gauge, note the vac at idle, prob around 16-19, now hold the throttle to like 2500ish RPMs and hold it there, the gauge will drop for a sec to about 10ish <-number doesn't matter, now what should happen is the vac should go back to the idle vac noted above, if the vac starts to drop off (move towards zero) you have a plugged cat.
I do.
Yes it IS possible, I do it all the time....Can you figure out how?
Report this Post04-10-2015 12:38 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suppose you're referring to a "boosted" engine?
sardonyx247
Total ratings: 219
Report this Post04-10-2015 12:44 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Also besides boost at wide open throttle you are at zero vac.
And if you want to get real technical, vacuum doesn't exist, just the lack of atmospheric pressure.
Report this Post04-10-2015 02:39 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
And that's a whole lot of help in this thread... unless unknown to LaFierte he has a boosted engine.
...vacuum doesn't exist, just the lack of atmospheric pressure.
Hunger doesn't exist, just the lack of food.
[This message has been edited by Patrick (edited 04-10-2015).]
1Packrat
Report this Post04-10-2015 08:14 AM Click Here to See the Profile for 1PackratSend a Private Message to 1PackratEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sticking EGR valve. Remove the Valve and check for carbon buildup on it.
tebailey
Report this Post04-10-2015 08:31 AM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Metal expands when it heats up changing clearances, so a hot engine could tighten up a valve. They also run hotter under a load.
LaFierte
Report this Post04-10-2015 09:51 AM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I think the cake might go to sardonyx247 for this one. It didn't show too much out of the ordinary at 2500, but at around 3000 it acted up pretty terribly. (I decided to try it a little higher since my car has an 84 transmission with 4:10 gears. The RPMs run a bit higher than a normal 86-88 gt while driving.) This would make sense. If it really is the problem--- I'm staying reserved since I've thought it had been resolved before--- I'm guessing that the distributor cab and rotor failed, was about to run through arcing, which explains the missing... That back firing likely was what burnt out the O2 sensor as mentioned. And back firing enough to burn out a O2 sensor could for sure melt the cat.
I'll try to drop the exhaust this weekend and get it fixed. I'll post the results for you guys, and if anyone else has a problem like this in the future. Thanks guys!
ltlfrari
Total ratings: 127
Report this Post04-10-2015 10:36 AM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bit late to the game but does it smell of rotten eggs? That's a good sign the cat is clogged.
Mine got to the point the car would not run at all.
This is what he cat looked like when I opened it up:
Usual cause is running rich which causes too much raw gas to the cat. The cat goes into overdrive doing it's thing and gets so hot, it melts.
and of course, often the cause of running rich is a vacuum leak. That's what had happened on mine.
Dave
www.ltlfrari.com
Report this Post04-10-2015 10:43 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
So the back firing is the issue and the failures in the exhaust system are the result. Perhaps it's another sticking valve?
LaFierte
Report this Post04-10-2015 11:13 AM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow that is one ugly looking cat.
Gal, I'm going to drop the exhaust first since that last vacuum test points to it, if that isn't the problem then I'll be looking at the valves. As I mentioned the distributor cap was bad. The center pin on the inside was actually missing, so it was just arcing to run. It would back fire due to it. I'm guessing that the cat was just a victim of the original case. But I won't know for sure until I try.
Edit: my cat doesn't smell like rotten eggs, but was running a little rich before I replaced the cap and rotor.
[This message has been edited by LaFierte (edited 04-10-2015).]
Spoon
Total ratings: 61
Report this Post04-10-2015 11:00 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before getting to deep into this matter you may want to do a compression test on the cylinders cold & hot.
ps: This should be done BEFORE pulling the heads,...?/@#....................."just in case".
Spoon
f85gtron
Report this Post04-11-2015 07:15 AM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could also screw a compression tester in where the o2 sensor bung is and measure what the exhaust is up to...,before you drop trou..
LaFierte
Report this Post04-12-2015 10:28 PM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, compression test read good across the board. I dropped the exhaust, half the cat was in the muffler, melted. The other half was still where it should be, but lightly melted. I removed and replaced. The car has more power now, but still has that same old power/ vacuum loss when it has warmed up. It seems to only be when I am holding the gas constant, without any movement. As soon as I let off or step down on it I get vacuum back (although not all of it). Interestingly, if I do not try to correct it.... it'll lose power up until right around 1000 RPMs and the correct itself. Any new ideas?
[This message has been edited by LaFierte (edited 04-12-2015).]
f85gtron
Report this Post04-12-2015 10:34 PM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
The charcoal canister purge valve?
LaFierte
Report this Post04-12-2015 11:48 PM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I've checked everything else it seems... Any types on testing it?
f85gtron
Report this Post04-13-2015 12:28 PM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unplug and cap it off. You'll have to unplug the tank vent that terminates at the purge canister as well, so you don't build vacuum in the fuel tank.
LaFierte
Report this Post04-13-2015 09:49 PM Click Here to See the Profile for LaFierteSend a Private Message to LaFierteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Canister is good. Interesting, after changing out the ICM and the coil, and still having the problem... I found out the timing was off... But even with it timed right it is still running rich. I'll have to look into it more this weekend. In the meantime... And more ideas?
