  Simple question about aftermarket oil pressure gauge
Simple question about aftermarket oil pressure gauge by IanT720
Started on: 04-08-2015 11:50 PM
Replies: 4 (756 views)
Last post by: rogergarrison on 04-09-2015 05:49 PM
IanT720
Report this Post04-08-2015 11:50 PM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Quick question, I don't trust the stock GT gauges on my Fiero so I bought 4 aftermarket gauges to replace them.
Oil pressure
Trans temp
Water Temp
Boost
For the oil pressure sensor I removed the stock 3800 one, and put in a T that goes to the turbo oil feed and the new sensor. Do I have to have the stock 3800 sensor too? If so what do I do with it? Does the pcm need it?
Also is that test port a good spot for the trans temp sensor? I hear it's an iffy spot.
Last question... Do I need any of the new sensors or can I splice the new gauges into the stock wiring? If so, I need a pinout. Thanks!
1987 Fiero GTX 3800 Turbo... My Build, ST3 Cam, Lowered, Wheels, and pics enjoy!https://www.fiero.nl/forum/Forum1/HTML/089483.html
johnguzman1212
Report this Post04-09-2015 01:40 AM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
I too am doing a 3800 swap I have an oil cooler with a oil pressure and temp sensor and wondering if I can tee off the OEM oil pressure hole to plug in my two sensors. Do I need that OEM oil pressure sensor there? Sorry bout the hijack but no one is helping me with my build
Mike Gonzalez
Total ratings: 130
Report this Post04-09-2015 09:28 AM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
Of those sensors the water temp is the only one the PCM looks at. You only need the Fiero sender to run the Fiero gauge. I have heard of people using T's for multiple senders, not sure it would be accurate on certain senders though. On my 4T45E i have hat the trans temp gauge where you can see the sender in this pic just to the left of the dipstick and it has seemed to work well.
IanT720
Report this Post04-09-2015 09:52 AM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks mike! That's what I needed to know, and to the other poster I put a T in the stock oil port, one end for the turbo oil feed, other for the oil pressure gauge. It works great!
rogergarrison
Total ratings: 551
Report this Post04-09-2015 05:49 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like oil pressure gauges with the hollow plastic or copper tube. Im not a fan of electrical gauges. Same with temp...I like the solid core type.
