  3800 heater hose
3800 heater hose by johnguzman1212
Started on: 04-08-2015 10:41 PM
Replies: 2 (271 views)
Last post by: johnguzman1212 on 04-16-2015 06:17 AM
johnguzman1212
Report this Post04-08-2015 10:41 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK I'm doing a 3800 swap done the search function. I'm going to tap the lim for the heater hose. Plug the water pump return. Can I cut trim the tension bracket and leave bolt holes?
Mike Gonzalez
Total ratings: 130
Report this Post04-10-2015 01:26 AM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not too sure what youre asking, but yes as long asy our no longer using the coolant passages in the bracket you can modify it within reason. Hope that is what you were asking :-)
johnguzman1212
Report this Post04-16-2015 06:17 AM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
yes I think it is... the two heater outlets I don't need I kust need the tensioner part so im guessing I can trim it leaving bolt holes? somebody stop me if im about to do a no no. im tapping lim and freezeplugging the water pump in let on my 3800sc swap
