  Engine Swap for Fuel Economy AANNNDDD capable of handling turbo?
Engine Swap for Fuel Economy AANNNDDD capable of handling turbo? by coltonandrew
Started on: 04-03-2015 08:01 PM
Replies: 1 (169 views)
Last post by: FieroLou on 04-03-2015 08:07 PM
coltonandrew
Report this Post04-03-2015 08:01 PM Click Here to See the Profile for coltonandrewSend a Private Message to coltonandrewEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a basic piss in the wind post. I want to do an engine swap on my 86 base model 2.5 5 speed.
I would love to find a torquey 4 banger that can handle moderate mid range boost (T3)
I have not started anything on the potential build, and it is my daily driver. I was wondering is anyone knew of any good engines that are 'plug and play' with minimal fabrication but that also might leave space for a good turbo build.
I don't want to spin the tires every day, and Id like to hover in the high 20s low 30s for mpgs. Its a lot to ask, so Im just seeing if anyone know of any engines capable of this.
Thank you!
Ideal power range after a full build is 220 bhp, though I will probably have to step to a v6 for that.
FieroLou
Report this Post04-03-2015 08:07 PM Click Here to See the Profile for FieroLouSend a Private Message to FieroLouEdit/Delete MessageReply w/QuoteDirect Link to This Post
It isn't exactly "Plug and play" but I know the GM Ecotec line has been swapped in. They were often turboed stock. Low displacement, and hopefully decent MPG
Others have swapped in the Quad 4 motor. I am aware they are often built to be really high horsepower. I don't know where the mileage numbers would come in. I've also read it is not an "easy" swap either.
Depends what you mean by plug and play.
Cheers!
1985 Pontiac Fiero 2M4
