Yeah, I've had this happen in occasion thru the years.. Lots of moving parts in the headlight assem.. Crank the motor up and check all the friction points,starting with the arm that comes off the motor itself,and then the pivot points of the assembly itself.
Another thing to check for is to make sure the plastic parts that suround the headlight at the bottom of assem aren't getting jammed into the wiring harness down inside the headlight bucket.. Check for any contact there..
And last but not least,the nylon gears might be on their way out and are cross threading once in a while and jamming up a bit..soon it'll be toast is this is the case..
Good luck!
[This message has been edited by Indyellowgt (edited 04-03-2015).]
