  HR6 compressor.
HR6 compressor. by tebailey
Started on: 03-31-2015 12:59 PM
Replies: 4 (199 views)
Last post by: tebailey on 04-01-2015 08:27 PM
tebailey
Report this Post03-31-2015 12:59 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a new reman HR6 compressor on my 84 Duke. I have the dreaded case leaks from a bad rear mount. Is it possible that if I correct the mount problem and re-torque the case bolts that the compressor will re seal?
sardonyx247
Total ratings: 219
Report this Post03-31-2015 10:43 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
If it's new can you warranty it?
tebailey
Report this Post04-01-2015 12:09 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Waited too long to install it, just wanted to know if the case is straightened and re-tightened if the O-rings will reseal.
notwohorns
Report this Post04-01-2015 08:07 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Usually when they start leaking they don't stop. Replacement is necessary
tebailey
Report this Post04-01-2015 08:27 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what I was afraid of. Was hoping someone had some luck with one. Thanks.
