   Fog lamp install, Bottom rear lights not working
Fog lamp install, Bottom rear lights not working by FGT88
Started on: 03-31-2015 10:25 AM
Replies: 4 (170 views)
Last post by: FGT88 on 03-31-2015 01:40 PM
FGT88
Report this Post03-31-2015 10:25 AM Click Here to See the Profile for FGT88Send a Private Message to FGT88Edit/Delete MessageReply w/QuoteDirect Link to This Post
2 questions the 2 red rear lights on the bottom of the Fiero do not work ? are they backup lights? or just decals?
question 2 I am putting fog lamp in how can I run the hot wire to the fuse box inside do I have to drill a hole or there is a way?
Thanks
Mike Gonzalez
Total ratings: 130
Report this Post03-31-2015 10:32 AM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
The two rear reds on the "bumper" are just reflectors. You may be able to run your wire through the steering column grommet.
Report this Post03-31-2015 10:56 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes, rear is reflectors. Require to meet DOT/FMVSS rules because taillights don't have them built in that many others do.
Is labeled DOT A etc.
Label Codes, See my Cave, Lighbulbs at bottom of page.
"You may be able to run your wire through the steering column grommet."
Make sure nothing can rub thru the wire. I would find/make other places...
Wiring, See my Cave, Fog/Driving lights
Report this Post03-31-2015 01:31 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The C-100 connector that is down above the gas pedal has a wide plastic cuff around it that allows for drilling a hole for your application. Drill the hole slightly larger than the wire and wrap a few turns of electrical tape around the wire to act as a grommet to protect the wire and seal the hole.
FGT88
Report this Post03-31-2015 01:40 PM Click Here to See the Profile for FGT88Send a Private Message to FGT88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the help
