  fan not running
fan not running by mark schuyler sipe
Started on: 03-28-2015 06:38 PM
Replies: 8 (236 views)
Last post by: theogre on 03-29-2015 12:15 PM
mark schuyler sipe
Report this Post03-28-2015 06:38 PM Click Here to See the Profile for mark schuyler sipeSend a Private Message to mark schuyler sipeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have indy fiero # 374. so, it's getting warmer and decided to get a new battery and fill up the motor and trans. it 's been sitting in the garage over the winter and hasn't been started in a few months. everything seems ok except I couldn't get the fan to run.I turned on the a.c. and it worked fine but still no fan. I hooked the fan to a battery and it runs. any suggestions?
Total ratings: 458
Report this Post03-28-2015 06:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Checked the fan relay?
Harley95
Report this Post03-28-2015 06:52 PM Click Here to See the Profile for Harley95Send a Private Message to Harley95Edit/Delete MessageReply w/QuoteDirect Link to This Post
I second the relay, mines hooked up with a toggle switch because it doesn't come on soon enough
mark schuyler sipe
Report this Post03-28-2015 06:56 PM Click Here to See the Profile for mark schuyler sipeSend a Private Message to mark schuyler sipeEdit/Delete MessageReply w/QuoteDirect Link to This Post
no. I thought the a.c and fan ran on the same relay in a 1984.
Total ratings: 458
Report this Post03-28-2015 07:21 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know what you're doing, but so far you've posted this same question four different times. I'm sure it's by accident... but hopefully you can figure out what's triggering this.
Total ratings: 568
Report this Post03-28-2015 08:34 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
84 w/ AC use three switches and two relays inside one part to control two speed fan motor.
Start w/ See my Cave, Rad Fan
Both speed dead then check fuse and front grounds. maybe relay or relay's red wire. Already test motor...
DKcustoms
Report this Post03-29-2015 03:01 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
idk how to fix this, but im sure making multiple threads doesnt help
TopNotch
Total ratings: 60
Report this Post03-29-2015 11:56 AM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Our fan motors are very old, and sometimes they die. It died on my 88 coupe. If you can't find another Fiero fan, you can mount one of these on the Fiero fan frame, after a little cutting of the frame:
Spal 30100400 16" Low Profile Fan
Uses less electric power, and moves more air than a Fiero fan.
Total ratings: 568
Report this Post03-29-2015 12:15 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe but Often is not user... The Device, browser or even ISP w/ problems causing reposting.
This thread... Started on : 03-28-2015
05:02 PM first
06:38 PM this because had most posts
07:09 PM
07:11 PM
With exact same text.
PFF only limits posting under 1 minute between posts.
[This message has been edited by theogre (edited 03-29-2015).]
