  Installing factory subwoofer-help?
Installing factory subwoofer-help? by mnsportsguy1966
Started on: 03-25-2015 08:04 AM
Replies: 3 (209 views)
Last post by: mnsportsguy1966 on 03-25-2015 06:50 PM
mnsportsguy1966
Report this Post03-25-2015 08:04 AM Click Here to See the Profile for mnsportsguy1966Send a Private Message to mnsportsguy1966Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am in the process of installing the oem subwoofer system into my 88 gt.
I have gone the complete installation process by taking the dash and gauges all out.
I got to tell you I'm just hoping I remember how to put everything back...Anyways
I have gotten my subwoofer speaker into place and a couple questions. Does the left slanted
bracket where the chime is go on top of or underneath the bracket and the same question for the bracket
to the outside... and what screws or bolts to use? there's more than 1 hole, a large and small one
on both brackets...any help would be very appreciated..
Lou and Blue
Report this Post03-25-2015 02:41 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the same setup that I will be installing this summer. Please PM me with the installation instructions you have. You can email me if its an attachment file.
Thanks
Louis
Louis Duet
Baldwin, Long Island, NY
"Blue" <= '85 Fiero GT
3800sc series 2 swap in progress
"Boo" <= '81 Delorean DMC-12
VIN #5835
Stock PRV engine
Peugot 604 Intake manifold
Exhaust headers
Anti-3rd brake light
Orig88GT-NC
Report this Post03-25-2015 05:47 PM Click Here to See the Profile for Orig88GT-NCSend a Private Message to Orig88GT-NCEdit/Delete MessageReply w/QuoteDirect Link to This Post
My dash is currently apart, sub-woofer was out... just tacked in place to take a photo ( I left the Screws loose )
the brackets on the speakers mount to the bottom of the ones in the vehical, The large hole on the RH side is for a larger screw that screws into the dash when its in place....
Left side
Right side ( easier if the courtesy light is removed to get the screw in)
Hope this helps
mnsportsguy1966
Report this Post03-25-2015 06:50 PM Click Here to See the Profile for mnsportsguy1966Send a Private Message to mnsportsguy1966Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, thanks for the reply...I think I now know which way to put in.
Sorry, but your pictures didn't show up though...I do know now
what your talking about with when I put the dash back on there is the
lower bolt/screw to on each side. Also I have found out that my headliner
is crumbling apart as I had to pull it back to get to the overhead/inside middle
console. I figure this would be a good time to also put in a new headliner.
Anybody know the best place to get a headliner? I know they have them
at the Fiero store. I have a sunroof but am not sure it's original so not sure
which way to go...any more help is appreciated...
