  Fan Switch wiring inquiry
Fan Switch wiring inquiry by NeverFamous
Started on: 03-24-2015 04:54 PM
Replies: 2 (148 views)
Last post by: NeverFamous on 03-24-2015 05:29 PM
NeverFamous
Report this Post03-24-2015 04:54 PM Click Here to See the Profile for NeverFamousSend a Private Message to NeverFamousEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys/Gals long time no post- I have a unique problem (almost sorted) So the PO wired a dohicky to the fan switch,possibly a o2 sensor connection. The first image has been identified as the correct and needed plug (see image) thanks to Steve with fiero addicts on facebook. My question is this: where does the wire go? (not plug-obviously to fan switch) and what color is the stock wire? Currently i can see a green wire with a white stripe coming from a black sheeth- that is connected to a red pigtail which leads to the wrong plug (image 2). I assume it should be straight forward- cut the red off attach the correct pig and click the plug on to fan switch.
I just want to wire in the new fan switch wire no problems.So any pointer on wire location and color is helpful. I have replaced all this with no air in system and no kinks in tubing with fresh (maybe 2 month old fluid)- radiator, heater core, fan switch, fan relay (in front or driver side headlight in front compartment), radiator cap -front and rear, Coolant temperature sensor.almost there the wife wants her heater!
[img]
What i see [img]
fieromatty
Report this Post03-24-2015 05:20 PM Click Here to See the Profile for fieromattySend a Private Message to fieromattyEdit/Delete MessageReply w/QuoteDirect Link to This Post
That connector from the top image is actually from a AC condensor.
The bottom image's connector looks out of place, Im 99% sure it belongs to the o2 sensor on the ypipe but it looks out of place.
The fan switch wire is darkgreen with white stripe.
Hope that helps.
[This message has been edited by fieromatty (edited 03-24-2015).]
NeverFamous
Report this Post03-24-2015 05:29 PM Click Here to See the Profile for NeverFamousSend a Private Message to NeverFamousEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats the answer i wanted Dark Green and white stripe! Good stuff! Thanks!
