  Door Ajar light on and has me stumped
Door Ajar light on and has me stumped by 88cryan
Started on: 03-22-2015 08:20 PM
Replies: 4 (562 views)
Last post by: 88cryan on 03-23-2015 02:19 PM
88cryan
Report this Post03-22-2015 08:20 PM Click Here to See the Profile for 88cryanSend a Private Message to 88cryanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello everyone,
I have been reading the forum for a couple hours now and I am not finding any similar problems/solutions as to why my door ajar light is on with all doors/trunk closed and ignition off on my 1988 GT.
Back story: A few years ago I took the bulb out of my trunk light because the switch went bad causing the light to stay on all the time and killing my battery. Well, fast forward to today and I'm finally getting around to all the little things on my car that I want to make right after getting the mechanical problems squared away.
Today I installed my new fierostore trunk switch and new light bulb. Bulb works great and when I close the switch manually the light goes off, however when I close the switch the ajar light illuminates on the dash. Oddly enough when I take the bulb out the ajar light goes off which makes no since to me because they are seperate circuits and really the ajar circuit isn't supposed to have power with ignition not in run according to the diagram.
tebailey
Report this Post03-22-2015 08:39 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check your grounds, bad grounds do weird things.
Report this Post03-22-2015 09:23 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
make sure the Fiero Store connector has the wires in the right places.
Report this Post03-23-2015 01:33 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The trunk light bulb is part of the circuit to the Ajar light. There must be power going through the bulb to make the Ajar light come on. A blown bulb or removing it will make the Ajar light stay off.
88cryan
Report this Post03-23-2015 02:19 PM Click Here to See the Profile for 88cryanSend a Private Message to 88cryanEdit/Delete MessageReply w/QuoteDirect Link to This Post
UPDATE....
I took the new fierostore trunk switch out and put in an old one that works and I no longer have the issue. I contacted the Fierostore and they are sending me another switch. It must be defective and allowing the light voltage over to the ajar circuit?
