  fuel pump/ac relay replacement
fuel pump/ac relay replacement by tshark
Started on: 03-21-2015 07:29 PM
Replies: 4 (355 views)
Last post by: donuteater306 on 03-22-2015 10:03 PM
tshark
Total ratings: 68
Report this Post03-21-2015 07:29 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
LornesGT
Report this Post03-21-2015 10:41 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't recall exactly how I did remove it but it is the engine side if the same as the 86. If I remember I will look tomorrow.
donuteater306
Report this Post03-22-2015 01:46 AM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
remove the lid, remove the filter, unplug the air temp sensor, and lift out the air cleaner housing. The bottom of the housing is mounted seperately and does not need to come out.
tshark
Total ratings: 68
Report this Post03-22-2015 01:13 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
donuteater306
Report this Post03-22-2015 10:03 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome, glad you were able to get it apart. Make sure you cap the larger hole. It was part of the PCV system, prior to the recall. The smaller vacuum hose is just the bleed-off for the EGR solenoid.
Keep in mind, this air filter set-up works from the inside, out. So any holes in the metal housing allows unfiltered air into the intake.
