  Oil Leak
Oil Leak by earp
Started on: 03-21-2015 06:19 PM
Replies: 3 (145 views)
Last post by: 2.5 on 03-23-2015 12:56 PM
earp
Report this Post03-21-2015 06:19 PM Click Here to See the Profile for earpSend a Private Message to earpEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got the new fuel pump installed in a nice clean tank. Engine started, but now the 2.5 has developed an oil leak somewhere
in the "middle" of the engine. I can't really see the source clearly. Could this be a leaky pressure sending unit? If so how do I get to it?
Csjag
Report this Post03-21-2015 07:10 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
It could be the valve cover gasket, on my 85 2M4 that had sat several years before I got it the valve cover gasket was all dried out and leaked badly. If you replace it use the rubber, most expensive Fel pro gasket.
earp
Report this Post03-21-2015 07:28 PM Click Here to See the Profile for earpSend a Private Message to earpEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks !
Report this Post03-23-2015 12:56 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Valvecover gaskets are usually the first oil gasket to leak on any engine I've ever had, its a good bet. If you replace it I recommend the ribbed blue one from Fel Pro, not cork.
