  motor mounts
motor mounts by johnguzman1212
Started on: 03-20-2015 10:54 PM
Replies: 5 (770 views)
Last post by: johnguzman1212 on 03-21-2015 11:30 PM
johnguzman1212
Report this Post03-20-2015 10:54 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
ok I used the search function and ogres cave. I ordered what I thought was the passenger side front motor mount for my 3800sc engine swap, a guy is making a bracket for my new engine but it will be using the oem mount, so I need a number I found on ebay anchor 2548 does this item number sound familiar? it looks the same, the mount they sent me almost fits my trans mount I guess I can drill new holes to fit the new trans mount on the trans mount its just off half an inch no biggie but I still need the big mount that goes under the crankshaft can I just adapt another trans mount here?bty I have the 2,5 duke 87 fiero it has a dogbone trans mount and engine mount ...3 all together
Macarchie
Report this Post03-21-2015 06:39 AM Click Here to See the Profile for MacarchieSend a Private Message to MacarchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Be aware that the front mount (under the passenger side - where the timing chain is located) is different between the auto and 5-speed. My driver is a 2.5 with a 5-speed and I took the front mount off of another '87 that had a 2.5 with an auto and the mounts (and mounting holes) are different. The holes are about an 1/2 inch closer together. It doesn't make sense to me that they would be different - they are at the opposite end of the motor (away from the tranny).
Good luck. Jimmy
1987 Fiero coupe; Blue; 2.5L; 5-spd
1987 Firebird Formula; Blue; 5L; 5-spd
Riddick85
Report this Post03-21-2015 10:42 AM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
This mount with the bolts sticking the same direction is the trans mount closest to the driver.
http://www.autozone.com/dri...fi-hp/155507_0_2362/
This mount with the bolts offset from each other is the trans mount mount closest to the trunk.
http://www.autozone.com/dri...fi-hp/155580_0_6134/
This mount is the front motor mount from a 2.8 that I used in my 3800 swap.
http://www.autozone.com/ext...fi-hp/554451_0_4302/
This I believe is the other motor mount (I've never worked with a 2.5 or really an auto so not sure)
http://www.autozone.com/ext...i-ohv/585042_0_4302/
LornesGT
Report this Post03-21-2015 09:44 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
How long have you had those mounts installed? I have heard they don't hold up.
Riddick85
Report this Post03-21-2015 11:27 PM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't use the duralast ones specifically I used anchor which is oriely brand at first but I switched to poly from rodney before anything went bad.
The only mount that will go bad in a short amount of time will be the trans mount nearest to the driver. There is quite alot of force applied to it and I broke 3 with my 200hp 3.4 I took out.
johnguzman1212
Report this Post03-21-2015 11:30 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
the last link is the mount my 2.5 duke has the big twinkle! so now my question is can I use either one the trans and another trans ? these mounts are cheap I got money I guess ill just order it and see. thanks for the links I really appreciate it
