  Please Help - Fiero GT 2.8 Stock Fuel Line to Rail Flare Nut Size
Please Help - Fiero GT 2.8 Stock Fuel Line to Rail Flare Nut Size by Ponnari
Started on: 03-20-2015 06:30 PM
Replies: 5 (901 views)
Last post by: css9450 on 03-21-2015 07:03 PM
Ponnari
Report this Post03-20-2015 06:30 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello everyone, searched but didn't find a definite answer and I need to know for sure before I start my project. What size flare nut wrench do I need to remove the fittings that hold the fuel lines to the fuel rail (see pic below).
Thanks in advance for the info.
"Because in a split second, It's gone"
Ayrton Senna
css9450
Total ratings: 86
Report this Post03-21-2015 08:16 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmmm, no one yet?
I think they're both 16mm, or it could be a 16 and a 17. Its been awhile for me.
Ponnari
Report this Post03-21-2015 05:26 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks css9450, anyone else?
85 SE VIN 9
Report this Post03-21-2015 06:03 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just took some wrenches out and checked. The 15mm won't fit, the 17 is too big. I don't seem to have a 16mm, but 5/8" equals 15.88mm. I could check a 5/8", but without taking the plenum or anything else off it might not be fit.
5/8
I checked. 5/8" fits great. Now that you mention I wondered the same thing and tried the TFS lines when they were here. There's a reason it's hard to find 16mm wrenches - you're expected to use 5/8".
Ponnari
Report this Post03-21-2015 06:38 PM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks so much 85 SE VIN 9 for taking the time to check this out and the answer.
Much Appreciated!
css9450
Total ratings: 86
Report this Post03-21-2015 07:03 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Makes sense.... Might be a standard (SAE) size rather than metric.
I didn't have a 16mm wrench either and had to buy it just for this task. Haven't needed it since!
