  3800 swap wires through rear firewall?
3800 swap wires through rear firewall? by johnguzman1212
Started on: 03-15-2015 12:37 PM
Replies: 2 (405 views)
Last post by: johnguzman1212 on 03-15-2015 08:49 PM
johnguzman1212
Report this Post03-15-2015 12:37 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
Help. im doing a 3800 swap in my 87 fiero as I started to remove the duke I noticed the "plug connector " that goes through the firewall is not a connector but a grommet that runs through can I just cut all the wires here? Im planning on making a special connector here which I thought was a plug to plug in my duke back incase my swap goes to hell and I can just simply plug back in my duke harness. I know theres another one passenger side Im not cutting this one cause its needed here and does not connect to my engine . the c500 just disconnects so no problem there. so ok to cut here? also I noticed my ac and fuel pump relay came off with the harness since im doing the hot mod fuel pump relay I don't need this and ill figure out the ac later
Report this Post03-15-2015 12:55 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do not cut the wires.
The driver-side pass-thru harness connects to the ECU, C-203 and ALDL.
Simply remove the connectors and pull the harness thru to the engine side.
Your new swap harness will connect to the PCM, C-203, and the OBDII ALDL.
[This message has been edited by olejoedad (edited 03-15-2015).]
johnguzman1212
Report this Post03-15-2015 08:49 PM Click Here to See the Profile for johnguzman1212Send a Private Message to johnguzman1212Edit/Delete MessageReply w/QuoteDirect Link to This Post
thank you for the fast response I cut the tape wrap all the way I didn't know they separated. I wish I had known that when I did the 10 inch stretch geez
