  2.8 Wont run at anything close to an idle speed. was idling and running great
2.8 Wont run at anything close to an idle speed. was idling and running great by jjolman
Started on: 03-13-2015 05:16 PM
Replies: 5 (190 views)
Last post by: AL68 on 03-15-2015 12:02 AM
jjolman
Report this Post03-13-2015 05:16 PM Click Here to See the Profile for jjolmanSend a Private Message to jjolmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
one day it died, will only start with 3 batterys spinning fast and use starting fluid. once it's running if you keep the rpm up it pulls smooth and runs well, but if I let the rpm drop it shuts off like I turned off the key. the way it shuts off seem only electrical as adding throttle has zero effect. I ruled out vacuum leaks because once it starts to die the throttle has no effect (like someone turned off the key) replaced coil, icm, .... it has fuel, plugs are wet (fuel) when I pull them out
FIEROPHREK
Total ratings: 137
Report this Post03-13-2015 05:37 PM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is it a 2.8? If it is check your 2 injector fuses.
12.3 is faster than a 13.2
Report this Post03-14-2015 08:54 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Start with 3 batteries? I hope that does not mean what I think it might mean.
Twinpilot001
Report this Post03-14-2015 12:08 PM Click Here to See the Profile for Twinpilot001Send a Private Message to Twinpilot001Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check /=replace tps??
Spoon
Total ratings: 61
Report this Post03-14-2015 06:20 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Were those (3 ) batteries connected in series or parallel ? Juuuuuust curious...... #$@%
Spoon
AL68
Report this Post03-15-2015 12:02 AM Click Here to See the Profile for AL68Send a Private Message to AL68Edit/Delete MessageReply w/QuoteDirect Link to This Post
might have a ruptured fuel pressure regulator if it's a v6, sucking fuel into engine
unplug vacuum hose to regulator & see if the end is wet with fuel or if any fuel leaks
out of the regulator when you turn on the key
