  fiero shuts off.
fiero shuts off. by AaronM
Started on: 03-13-2015 11:45 AM
Replies: 6 (184 views)
Last post by: AaronM on 03-13-2015 04:50 PM
AaronM
Report this Post03-13-2015 11:45 AM Click Here to See the Profile for AaronMSend a Private Message to AaronMEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok i have a 1995 pontiac fiero. long story shoshort it dies maybe after ten minutes of running. Ive replace the fuel pump about a year ago and filter, ive also replaced the oil sender and the senders cconnector, fuel pump relay and now the ignition coil. Im only 18 and just want a soild running fiero so please help. It just shuts off like you turn the key off. You even here the pump when it shits off.
F1ero Kid
Report this Post03-13-2015 11:54 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you try to re-start it after it stops, look to see if the tachometer needle moves a little when you crank the starter. If it just sits on the peg, you probably have lost your ICM.
AaronM
Report this Post03-13-2015 12:03 PM Click Here to See the Profile for AaronMSend a Private Message to AaronMEdit/Delete MessageReply w/QuoteDirect Link to This Post
It does move when i restart the car. After it dies after the twenty minutes it dies even quicker once i restart it, like maybe within 3 to 5 minutes.
Report this Post03-13-2015 12:14 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
If it starts immediately after stopping, then the problem might be something else. Usually when a bad ICM gets warm and goes bad, it needs to cool off for a while before the car starts again.
AaronM
Report this Post03-13-2015 12:20 PM Click Here to See the Profile for AaronMSend a Private Message to AaronMEdit/Delete MessageReply w/QuoteDirect Link to This Post
Itll start after but each time you restart it thereafter the run time gets shorter and shorter to the point it wont start anymore till you let it sit for a while.
FIEROPHREK
Total ratings: 137
Report this Post03-13-2015 01:09 PM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like an ignition control module. Pull it off and take it to autozone and have them test it. When they test it have them test it about 5 times to get it nice and warm.
12.3 is faster than a 13.2
AaronM
Report this Post03-13-2015 04:50 PM Click Here to See the Profile for AaronMSend a Private Message to AaronMEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the icm and hey what do you know, shes beautipul, thanks ill be sure to reupdate later if shes better.
