  fuel pump won't stop running !
fuel pump won't stop running ! by Lou6t4gto
Started on: 03-12-2015 10:22 AM
Replies: 3 (143 views)
Last post by: Shho13 on 03-17-2015 01:44 PM
Lou6t4gto
Report this Post03-12-2015 10:22 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
A friend stopped over yesterday with a 1986 GT 2.8 stick. The fuel pump starts running when key is turned on, And Does NOT shut off at all. Fuel pump "sender" ?? What else to check ? Thanks
Total ratings: 207
Report this Post03-12-2015 10:30 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stuck relay or oil pressure sender.
Unplug one or the other, see which one it is.
Puglet01
Report this Post03-16-2015 12:30 PM Click Here to See the Profile for Puglet01Send a Private Message to Puglet01Edit/Delete MessageReply w/QuoteDirect Link to This Post
On mine it was the oil pressure sending unit but my fuel pump ran all the time till the battery died.
Shho13
Report this Post03-17-2015 01:44 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
Usually shorts through the oil pressure sending unit... unplug that first and see what happens, then if no luck check the relay.
If it's the sending unit, just replace it with a new one. Look up how to modify your car to accept the 1988 version of the sending unit, its simple to do. They are much more reliable and a lot less expensive.
Edit: Here is the link to the modification if you choose to do it!
"Discord"
( ͡° ͜ʖ ͡°)
[This message has been edited by Shho13 (edited 03-17-2015).]
