  4 Banger Starter R&R
4 Banger Starter R&R by Keel
Started on: 03-10-2015 01:16 PM
Replies: 4 (128 views)
Last post by: theogre on 03-10-2015 10:40 PM
Keel
Report this Post03-10-2015 01:16 PM Click Here to See the Profile for KeelSend a Private Message to KeelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just did an oil change on my Fiero, and lately it's been cranking slow. So I figured I'd look at the connections.
Well the starter casing for the motor (black part) and the end cap for the motor are loose, it looks like there should be 3 bolts holding the end plate, or at least 2. There is only one..
Can you snake the starter out of the car without undoing other parts? it has the Original converter on it (pellet) .
Figured I'd ask if there is a trick to getting it out, or what has to be removed..
Thanks..
jaskispyder
Total ratings: 205
Report this Post03-10-2015 01:58 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you can't just unbolt exhaust from header and lower exhaust a little. I changed mine with out a cat. in the way, so that doesn't help.
E.Furgal
Total ratings: 278
Report this Post03-10-2015 02:00 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
johnt671
Report this Post03-10-2015 06:00 PM Click Here to See the Profile for johnt671Send a Private Message to johnt671Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got the starter on my 84 out without pulling any other parts by sliding the starter over to the passenger side and trying different angles to get it to slide out. It took a bit of moving it this and that way to do it, but it can be done. If I remember right. the nose of the starter drops down when you hit the right spot, and then you have to move it around to find the spot to clear the solenoid to clear and it will come out.
If you can, replace the starter with one from a 3800 motor. I got one for a 98 Pontiac Grand Grand Prix GT. It's much smaller and lighter the the original starter, and makes the job a piece of cake. If you do this, you will thank me and pat yourself on the back. Try a search as there is a bunch of info in the forum about this starter.
Report this Post03-10-2015 10:40 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Changing starter can, often does, require shim(s). Using later design can need different shim setup.
See my Cave, Starter
