  side scoop adhesive?
side scoop adhesive? by vette7584
Started on: 03-06-2015 05:21 PM
Replies: 3 (287 views)
Last post by: 1shot on 03-09-2015 10:29 PM
vette7584
Report this Post03-06-2015 05:21 PM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
hello all, going to try and modify the side panels by adding scoops from a 1982 trans am. what adhesive works well with the material these side panels are made of? thanks
Report this Post03-06-2015 06:27 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Steven Snyder
Total ratings: 106
Report this Post03-09-2015 01:29 AM Click Here to See the Profile for Steven SnyderClick Here to visit Steven Snyder's HomePageSend a Private Message to Steven SnyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
The quarter panels are reaction injection molded (RIM) polyurethane. RIM is the process used to make the parts, not the material. In the case of the side panels, that material is a two-part polyurethane resin. Hence the name "reaction injection molding". You can't replicate the RIM process without extremely expensive mixing and injection-molding equipment, but you don't need to since you're just bonding the parts.
Unfortunately, it's pretty hard to bond with because you can't make new polymer chains with the base material of either piece as polyurethane is pretty much inert. You can't melt it together like a thermoplastic elastomer. The key properties for the adhesive will be flexibility and a similar coefficient of expansion. The correct surface preparation (surface roughness) on both parts will also help with the adhesion. If you look for an adhesive intended for flexible urethane bumper repair, that would probably be a good start.
[This message has been edited by Steven Snyder (edited 03-09-2015).]
1shot
Report this Post03-09-2015 10:29 PM Click Here to See the Profile for 1shotSend a Private Message to 1shotEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.tcpglobal.com/UR...R1.html#.VP5jkZV0w5s
This is a product I've used on polyurethane bumpers and it works well. But it only works on polyurethane that I know of. I'm not sure what the pieces from the Trans Am are made from.
