  Mark rear strut area so you dont need an alignment after replacing?
Mark rear strut area so you dont need an alignment after replacing? by 2.5
Started on: 02-27-2015 05:24 PM
Replies: 4 (465 views)
Last post by: Lou6t4gto on 02-28-2015 06:02 PM
Report this Post02-27-2015 05:24 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have heard some people mark the rear spindles and claim they dont need an alignment after replacing rear struts. Can this be done with an 86 Fiero? I wouldn't think so since the new struts may not be identical to the old ones?
Lou6t4gto
Report this Post02-27-2015 06:51 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hard enough with your old struts, new ones, Don't think so.
woodyhere
Report this Post02-27-2015 08:31 PM Click Here to See the Profile for woodyhereSend a Private Message to woodyhereEdit/Delete MessageReply w/QuoteDirect Link to This Post
I drilled a 3/16 hole for alignment in my old strut when I moved it which has nothing to do with what you asked. . A new strut isn't too hard to get pretty close by using one of those magnetic levels that magnetically stick to the rotor. It's just a matter of duplicating the setting when you adjust the new strut. Clear as mud!
woodys 427
Report this Post02-28-2015 03:51 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Making or using standard level can get close enough to drive.
Just use a digital level or plumb bob before then after is better. Both are more accurate.
https://www.fiero.nl/forum/F.../HTML/000031.html#p4
web search for diy alignment camber
Lou6t4gto
Report this Post02-28-2015 06:02 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
drilling the 1/8" hole is a good idea, I've always done that for other panels. to re align you just put in a 1/8" rivet and tighten the bolts.
