  torque spec. on bolts
torque spec. on bolts by jim94
Started on: 02-19-2015 09:35 PM
Replies: 1 (334 views)
Last post by: olejoedad on 02-20-2015 09:10 AM
jim94
Report this Post02-19-2015 09:35 PM Click Here to See the Profile for jim94Send a Private Message to jim94Edit/Delete MessageReply w/QuoteDirect Link to This Post
There is a bar behind the front cross member that has 4 bolts. I took the slightly rusted bar off my car painted it but I cannot find how tight to make the bolts plus there was lock tight on the bolts that I will re install the bolts with. I cannot even find it in the service manual.? Is it called a frame stiffener bar?
[This message has been edited by jim94 (edited 02-20-2015).]
Report this Post02-20-2015 09:10 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC, those are M8x1.25, 10.9 hardness.
Put some Loctite on them and tighten them to 20-25 ft/lbs.
[This message has been edited by olejoedad (edited 02-20-2015).]
