  main ignition wire
main ignition wire by chrislayton
Started on: 02-19-2015 05:30 PM
Replies: 1 (110 views)
Last post by: Gall757 on 02-19-2015 08:16 PM
chrislayton
Report this Post02-19-2015 05:30 PM Click Here to See the Profile for chrislaytonSend a Private Message to chrislaytonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I pulled the wiring harness from an 84 fiero to put in a project car along with the fiero steering column and electronics. I'm just trying to figure out what wire is the main positive lead on this harness that goes back to the battery. The entire harness is installed in this project vehicle ('68 meyer's manx) with the fuse box and everything. Does anyone have a wiring diagram that tells you if the largest gauge red wire that is at the end of this harness is the one that goes to the battery and which wire goes to the starter?
Report this Post02-19-2015 08:16 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Power distribution on the 84 was at the starter.
