  engine cradle
engine cradle by skidd1000
Started on: 02-15-2015 12:38 PM
Replies: 9 (746 views)
Last post by: skidd1000 on 02-17-2015 05:07 PM
skidd1000
Report this Post02-15-2015 12:38 PM Click Here to See the Profile for skidd1000Send a Private Message to skidd1000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello. I am looking for any help that I can get. I am putting a sbc in my project fiero and am looking for some tips or advice on the cradle. I picked up a rust free cradle for a manual car and want to use it for my automatic swap. What changes need to be made to make this work? Also what mounts are used? (th 125) And if anyone knows what exhaust manifolds work good that would help a lot. I bought some center dump block hugger headers but the back one comes out on top of the inner cv joint. Thanks in advance. Steve. I[img]https://images.fiero.nl/2012/rsz_1fiero_002.jpg">
'86 Fiero/Ferrari F355 kit car
skidd1000
Report this Post02-15-2015 12:40 PM Click Here to See the Profile for skidd1000Send a Private Message to skidd1000Edit/Delete MessageReply w/QuoteDirect Link to This Post
skidd1000
Report this Post02-15-2015 12:41 PM Click Here to See the Profile for skidd1000Send a Private Message to skidd1000Edit/Delete MessageReply w/QuoteDirect Link to This Post
skidd1000
Member since Feb 2014
fierosound
Total ratings: 287
Report this Post02-16-2015 10:17 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now would be a good time to put in a 4-speed automatic.
http://www.fieronews.net/fu...d=23&download_id=142
Calgary time/temp
skidd1000
Report this Post02-16-2015 04:55 PM Click Here to See the Profile for skidd1000Send a Private Message to skidd1000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks fierosound for the tip, but I like the three speed, and I just went thru it with new frictions and steels and bushings and seals. It has the 3.03 ratio and a 2830 stall converter with woven carbon clutch. This is just going to be a parade car, not a daily driver.
FIEROFLYER
Total ratings: 180
Report this Post02-16-2015 05:36 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
There is no difference in the 84 to 87 cradles between the auto and manual cars they even use the same rubber mounts. The 88 is the only year with a difference and that is just the addition of a tranny mount at the end of the tranny and only the 4 cyl cars had this if I remember correctly.
DARN Cars now open with
Bloozberry
Total ratings: 311
Report this Post02-16-2015 06:26 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
There may be better headers now, but when I built my sbc car I used the stainless '98 Corvette with A.I.R. (1 5/8" pri / 3.0" col)(P/N 14087511) for both sides. They're center dump, but they don't hug the block like many other styles do. I wish I could tell you they'll clear the auto transmission, but I can't be certain. They do clear the CV joint on the manual with lots of space though. I apologize for the crappy quality of the photo, but here's what they look like:
skidd1000
Report this Post02-16-2015 06:56 PM Click Here to See the Profile for skidd1000Send a Private Message to skidd1000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks fieroflyer. The cradle in my 86 auto has a transmission mount on the front and the rear of the 125 and the cradle that I picked up from an manual fiero has a large pad welded to the left side of the cradle where the manual transmission mount goes. The automatic cradle does not have this.You might be able to see the piece that I am talking about in the picture. I have not removed the original motor and trans from the car yet and am hoping to get the most of the work done to the v8 set up before I do pull the oe motor.
FIEROFLYER
Total ratings: 180
Report this Post02-17-2015 09:35 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Some one most likely added that pad on the driver's side for a non Fiero tranny as that is where the extra tranny mount piece I mentioned on the 4 cyl 88 auto cradle was. The 88 4 cyl auto only had two mounts one engine one tranny on this pad where all others had one engine mount and two tranny mounts one on each side of the tranny which was a lot stronger. I would just cut it off and carry on.
skidd1000
Report this Post02-17-2015 05:07 PM Click Here to See the Profile for skidd1000Send a Private Message to skidd1000Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks again fieroflyer. I will remove that pad and also the one in the front for the original motor mount, It,s not needed with the v8. Have you done a v8 automatic swap before? It looks like the original trany mounts wont work. The motor needs to be shifted as far left as possible so the harmonic balancer will clear the right side frame rail I am looking for some general measurements to go by.Archie has a measurement on his site for the center of the crank shaft to the right front cradle mount but nothing for the transmission side to keep everything squared up.
