  square bit size
square bit size by fieromatty
Started on: 02-12-2015 06:19 PM
Replies: 12 (237 views)
Last post by: jaskispyder on 02-13-2015 04:37 PM
fieromatty
Report this Post02-12-2015 06:19 PM Click Here to See the Profile for fieromattySend a Private Message to fieromattyEdit/Delete MessageReply w/QuoteDirect Link to This Post
For some reason, pontiac thought it would be a good idea to put a square bit plug where the fan temp switch usually goes. Does anyone know what size that bit is? I can't find it at any store.
A picture is on my website
magnetwd.com/car
Its the last picture on the page.
jaskispyder
Total ratings: 205
Report this Post02-12-2015 06:27 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't remember, but isn't it just 3/8".... or 1/2" (use a ratchet).
I have created my own, in the past by just grinding down a bolt, to the same size as the square hole.
(found this: http://www.thirdgen.org/for...-head-pipe-plug.html )
[This message has been edited by jaskispyder (edited 02-12-2015).]
Neils88
Total ratings: 56
Report this Post02-12-2015 07:20 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
+1 That was going to be my suggestion...
tebailey
Report this Post02-12-2015 07:33 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't know what they have on yours, but I know some GM's had 5/16 square plugs. Had to get a socket for a Caddy engine I had long ago.
fieromatty
Report this Post02-12-2015 07:46 PM Click Here to See the Profile for fieromattySend a Private Message to fieromattyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its smaller then the 3/8ths ractchet. I tried.
Taijiguy
Total ratings: 244
Report this Post02-12-2015 09:35 PM Click Here to See the Profile for TaijiguySend a Private Message to TaijiguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
1/4"?
Bloozberry
Total ratings: 311
Report this Post02-12-2015 09:44 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
The heads are interchangeable left to right... are you sure the head on the other bank doesn't have the plug already removed?
tebailey
Report this Post02-12-2015 09:54 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
They do make a socket for those 5/16 square.
Report this Post02-12-2015 11:06 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have seen one engine that was totally assembled and installed before they realized they'd put the heads on the opposite banks. They couldn't get the plug out so they ran a pair of wires across the engine to the temperature sensor at the right front of the engine.
darbysan
Report this Post02-13-2015 11:19 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a bunch of short 3/8" extensions, so I just ground one down. Same as grinding down the bolt.
'87 GT in process!
Bloozberry
Total ratings: 311
Report this Post02-13-2015 11:55 AM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have seen one engine that was totally assembled and installed before they realized they'd put the heads on the opposite banks. They couldn't get the plug out ...
Personally, I've never been able to get that plug out and neither has the machine shop where I get most of my work done. They're in there good and tight with 30 years of corrosion in the threads. My experience has been that the square socket in the head either rounds off or the tool does.
Report this Post02-13-2015 12:36 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Our mechanic that installed my 3.4 got the plug out of mine. The engine had good compression so we didn't want to pull the heads. I don't know how he did it, but he did. Freezing it with AC refrigerant and whacking it with a brass drift and small sledge can sometimes break them loose. Then use an impact wrench. I've used that method on the same type plugs in other applications.
[This message has been edited by fierofool (edited 02-13-2015).]
jaskispyder
Total ratings: 205
Report this Post02-13-2015 04:37 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my Jasper rebuild, it came out without a problem.
