  Recall 88-C-24 Have it performed or not?
Recall 88-C-24 Have it performed or not? by My88RedGT
Started on: 02-09-2015 12:21 PM
Replies: 3 (735 views)
Last post by: theogre on 02-09-2015 02:22 PM
My88RedGT
Report this Post02-09-2015 12:21 PM Click Here to See the Profile for My88RedGTSend a Private Message to My88RedGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 88 Fiero GT has never had recall 88-C-24 performed. I'm pretty sure this is the case since the PVC line from the valve cover is still mounted to the firewall and routed into the air filter canister. There is also no heat shield where the manifold connects to the heads. No campaign sticker either. Even GM's recall site says my vehicle is incomplete.
If I were to call GM and request I have this recall performed…Should I?? My reasoning for questioning this is the fact my Fiero is stock 2.8 with just over 34k original miles. It runs perfectly and I would hate to have something done to it and have it no longer run like it does now. I’ve performed routine maintenance on it, ex. change spark plugs, wires, valve seats, fuel injector cleanings, etc…, but removing the exhaust manifold and having it crack or a bolt breaking off is a great concern of mine.
If this was your 26 year old vehicle, would you have the dealer mechanic perform the work?
Opinions greatly appreciated.
tesmith66
Total ratings: 135
Report this Post02-09-2015 12:28 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Since the GM that recalled it no longer exists, I doubt they would honor it. Even if they did, they wouldn't be able to get the parts.
1986 SE Aero coupe.
Report this Post02-09-2015 01:36 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
NO! You already know more about the situation than they ever will. You are maintaining your Fiero better than they were treated by average buyers in the first place. If you inspect the PCV system annually, it won't come apart and dump oil on the catalytic converter.
Report this Post02-09-2015 02:22 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Old GM was hard to get them do to Recall work when Fiero was 10-15 years old.
New GM is a nightmare on recalls before Old was bankrupted.
Yes, Even if Recall is still valid the parts to do recall work are gone. Try Ebay for a recall kit or find used parts in a junk yard.
