  What to use to keep shifter console together?
What to use to keep shifter console together? by Tweeder
Started on: 02-08-2015 10:34 PM
Replies: 8 (513 views)
Last post by: Lou6t4gto on 02-10-2015 12:47 PM
Tweeder
Report this Post02-08-2015 10:34 PM Click Here to See the Profile for TweederSend a Private Message to TweederEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its the auto shifter surround. Its been hot glued twice and keeps comming apart, any suggestions?
86 SE Convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
Neils88
Total ratings: 56
Report this Post02-08-2015 11:38 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can you post a picture so we can see exactly where it has come apart...
gtoformula
Report this Post02-09-2015 09:57 AM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gorilla glue, but not sure how well it will work now that hot glue is on the vinyl material.
Report this Post02-09-2015 11:55 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Gorilla glue is what I have used as well. Follow instructions and use alot of clamps to hold it in place while it dries.
hnthomps
Total ratings: 50
Report this Post02-09-2015 01:43 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gorilla glue plus a lot of clamps worked for me also. One thing to be prepared for is that the glue expands and you will likely have to clean/scrape some of it off the console. It was a bit tedious but not a difficult job.
Nelson
commerce
Report this Post02-10-2015 01:46 AM Click Here to See the Profile for commerceSend a Private Message to commerceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had excellent results with JB Weld. It has held for many years now. It does take time and lots of clamps have to be used.
commerce
Report this Post02-10-2015 01:48 AM Click Here to See the Profile for commerceSend a Private Message to commerceEdit/Delete MessageReply w/QuoteDirect Link to This Post
commerce
Member since Dec 2008
I have also heard that Rhino glue works well. Sets up pretty fast. Sold on Amazon.
Report this Post02-10-2015 11:34 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you want a little more instruction on how this is done....here is a thread
Petey 2
[This message has been edited by Gall757 (edited 02-10-2015).]
Lou6t4gto
Report this Post02-10-2015 12:47 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Want it to LAST, Remove the Foam under padding, wash with some wax/grease remover, then use Gorilla glue Or GOOP.
