  engine problems
engine problems by sgosser
Started on: 02-04-2015 12:35 PM
Replies: 7 (182 views)
Last post by: therepairguy on 02-05-2015 05:42 AM
sgosser
Report this Post02-04-2015 12:35 PM Click Here to See the Profile for sgosserSend a Private Message to sgosserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey all. I was wondering what I should look for with my problem. My son borrowed fiero and it died on him. He said oil pressure went down and it died. When started cold it sounds ok but has slight knock when warm and less power than before. I have not heard it run. Going by what I was told that it sounded like may be valve knock. Oil seems fine but no pressure reading in dash. I wonder if it dropped a valve? any thoughts? thanks
dobey
Total ratings: 371
Report this Post02-04-2015 12:39 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oil pressure dropped and then a knock? Sounds like it might have spun a bearing. Have you checked the oil for metal and such? Sounds like first thing you should do is drain it and examine the oil (can use a strainer or a magnetic pick-up tool) for metal content. If a valve dropped, you'd probably have much worse than a slight knock.
I'd drain the oil, check it, and then pull the pan and check the bearings, depending on what you find when checking the oil.
Oolab1
Report this Post02-04-2015 01:37 PM Click Here to See the Profile for Oolab1Send a Private Message to Oolab1Edit/Delete MessageReply w/QuoteDirect Link to This Post
This sounds similar to what happened to me a week or two ago. Luckily it died as I was pulling into the driveway Not sure what it was but the next day it started and ran fine and it's been going great since. Well as good as possible for an old car in negative temps... Have you tried starting it since?
jaskispyder
Total ratings: 205
Report this Post02-04-2015 01:43 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put a mechanical gauge on there and check for oil pressure. If it is low, then you have a problem....
sgosser
Report this Post02-04-2015 02:40 PM Click Here to See the Profile for sgosserSend a Private Message to sgosserEdit/Delete MessageReply w/QuoteDirect Link to This Post
I haven't started it. May mess with it this weekend. I will check the oil first and let you know what i find.
Csjag
Report this Post02-04-2015 04:49 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this type of engine failure caused by over revving?
dobey
Total ratings: 371
Report this Post02-04-2015 05:31 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Over revving can stretch rod bolts and spin bearings, yes.
therepairguy
Report this Post02-05-2015 05:42 AM Click Here to See the Profile for therepairguySend a Private Message to therepairguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately it sounds like you have a serious mechanical issue. sorry
