  86 GT won't start
86 GT won't start by KidMichigan
Started on: 02-03-2015 03:34 AM
Replies: 4 (143 views)
Last post by: 85 SE VIN 9 on 02-03-2015 07:53 PM
KidMichigan
Report this Post02-03-2015 03:34 AM Click Here to See the Profile for KidMichiganSend a Private Message to KidMichiganEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey everyone. My 86 GT has been having some issues starting lately. I turn the key with the clutch and brake down and nothing happens. I can usually pop the clutch, but sometimes that proves futile. Wondering if anyone has that sort of issue, and how I might go about resolving it. Thanks!
Csjag
Report this Post02-03-2015 07:27 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the engine isn't even turning over try bypassing the neutral safety switch, I have had to bypass it on both of my Fieros.
Report this Post02-03-2015 08:29 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
No Neutral Safety Switch on a manual....
Check the Clutch Start Switch on the clutch arm.
Yellow/Purple, disconnect plug from switch and jumper the contacts in the plug.
If it starts, the switch is bad.
Report this Post02-03-2015 11:23 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check for basics like loose and/or corroded battery connections!
85 SE VIN 9
Report this Post02-03-2015 07:53 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cheap and effective fix for slipping neutral start safety switch (on clutch):
