  3800 wiring harness
3800 wiring harness by adifferentlook
Started on: 01-29-2015 11:23 AM
Replies: 2 (363 views)
Last post by: Tuna Helper on 01-30-2015 10:20 PM
adifferentlook
Report this Post01-29-2015 11:23 AM Click Here to See the Profile for adifferentlookSend a Private Message to adifferentlookEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello guys, i am doing a 3800sc swap in a 84 fiero.
i received a premade wiring harness from a builder.
i wasnt labeled well and i hooked the positive and negative up wrong on the battery.
After i figured it out, the car will only start if i spray
starting fluid in the throttle body. After i spray it ,it will run for awhile and want cut off.
i cant get in touch with the guy that built the harness,Anthony
FIEROFLYER
Total ratings: 180
Report this Post01-29-2015 12:52 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
If the computer was connected at the time it is most likely the problem and needs to be replaced
DARN Cars now open with
Tuna Helper
Report this Post01-30-2015 10:20 PM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you checked your fuel pressure?
