  Cruise Control
Cruise Control by steve308
Started on: 01-25-2015 02:29 PM
Replies: 5 (839 views)
Last post by: LornesGT on 01-25-2015 10:20 PM
steve308
Total ratings: 58
Report this Post01-25-2015 02:29 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Coming home from a C&C this morning my cruise control up and quit. The fuse is good and every thing on the engine end is connected. Open for suggestions on where to look next to trouble shoot. Thanks in advance.
Spoon
Total ratings: 61
Report this Post01-25-2015 05:16 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Theres a switch on the brake & clutch if you have a stick that can keep the cruise disengaged if they hang up or go out of adjustment.
I converted to digital cruise so I can't help you too much.
Spoon
mcguiver3
Report this Post01-25-2015 06:16 PM Click Here to See the Profile for mcguiver3Send a Private Message to mcguiver3Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree, my switch on the brake peddle was loose and not engaging. A zip tie and adjustment and all is well.
Check for a vacuum leak as well but probably one of the switches.
hnthomps
Total ratings: 50
Report this Post01-25-2015 06:41 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The cruise control selector/on/off switch is also a common source of problems with the stock Fiero cruise control.
Nelson
steve308
Total ratings: 58
Report this Post01-25-2015 08:03 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys. I'll check the pedal switch(s) and the stalk in the next couple of days. I'm thinking the pedal area makes the most sense as I do normally drive shoeless as my size 13 feet take up a lot of space. With the cold weather this morning I did have a pair of my cold weather clown shoes on. Hope it is a simple fix and I will post the results of either success or failure after I check.
LornesGT
Report this Post01-25-2015 10:20 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just found the reason for mine not working today, at the stalk where the wires exit.
