  18x8 -35 offset fitment pictures in thread
18x8 -35 offset fitment pictures in thread by ConvictedRedneck
Started on: 01-19-2015 10:32 AM
Replies: 10 (680 views)
Last post by: countach711 on 01-20-2015 08:33 PM
ConvictedRedneck
Report this Post01-19-2015 10:32 AM Click Here to See the Profile for ConvictedRedneckSend a Private Message to ConvictedRedneckEdit/Delete MessageReply w/QuoteDirect Link to This Post
A forum member PM'ed me asking about the fitment of my wheels, specifically how far they stuck out in the rear with a -35 offset on an 18x8 wheel. Instead of emailing him pictures, I figured I put it up here for reference as wheel fitment is a common point of confusion. The car is an '87 converted to coilovers in the rear. All four corners are 18x8 -35 wheels; tires are 245/40/18 rear, 225/40/18 front.
I feel like -35 is ideal for the rear but the fronts could probably -40 to -48 to look ideal, although I'm not sure if there would be any fitment issues. Maybe someone can chime in. He also asked about how wide of a tire could be run without hitting the coilovers. I can't comment on this specifically as the car is in storage and I don't recall exactly how much space was back there but in my opinion, on an 8-inch wide wheel, a 245 is already 9.65 inches wide. Maybe you could do a 255 or 265 but anything beyond that would require a 9 or 10 inch wide wheel, which would only work dependent on the coil clearance.
Hope this information was helpful!
My turbo build
[This message has been edited by ConvictedRedneck (edited 01-19-2015).]
Bloozberry
Total ratings: 311
Report this Post01-19-2015 12:37 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
It would be nice if you could post a top-down photo with the camera lens centered above the front fender lip with the wheels pointed straight ahead. I find almost everyone with wide rims and shallow offsets post photos with the wheels turned or from an angle that doesn't allow a fair assessment of how much they stick out.
ConvictedRedneck
Report this Post01-19-2015 04:27 PM Click Here to See the Profile for ConvictedRedneckSend a Private Message to ConvictedRedneckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree, I'll get some later this week. I wanted to provide somewhat of an idea before I could get to my car in storage.
Are the pictures working for anyone else? I show broken links even though I used PIP...
Bloozberry
Total ratings: 311
Report this Post01-19-2015 04:49 PM Click Here to See the Profile for BloozberrySend a Private Message to BloozberryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Idaho Wolverine
Report this Post01-19-2015 06:43 PM Click Here to See the Profile for Idaho WolverineSend a Private Message to Idaho WolverineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks nice! I do agree, the fronts look like they do stick out quite a bit. My Formula has that wider front too, but I still have the 15" wheels. I love the look of the 18"!
FTF Engineering
Report this Post01-19-2015 08:28 PM Click Here to See the Profile for FTF EngineeringSend a Private Message to FTF EngineeringEdit/Delete MessageReply w/QuoteDirect Link to This Post
SSR Integrals. One of my favorite wheels ever.
Looks great.
thesameguy
Report this Post01-19-2015 09:02 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is some sort of front brake conversion on there?
ConvictedRedneck
Report this Post01-19-2015 09:20 PM Click Here to See the Profile for ConvictedRedneckSend a Private Message to ConvictedRedneckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks great.
Thanks! I lucked out and found them used in perfect condition on the 5x100 VW wheel forum!
Yes, Grand Am brake conversion with drilled/slotted rotors.
FTF Engineering
Report this Post01-20-2015 08:51 AM Click Here to See the Profile for FTF EngineeringSend a Private Message to FTF EngineeringEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I did my swap I couldn't find the desired sizes for my car in the Integrals so I bought Mille Miglia MMII's instead.
I think the MMII's looked really good, but I think the Integrals look even better.
thesameguy
Report this Post01-20-2015 02:06 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is what leads to the wider front track. You've added ~10mm to each side of the front of the car. In order to counteract that, you need to run a numerically lower offset wheel in back than in front. In comparison to the factory configuration, you're actually running +35mm rear, and ~+25mm front. The Grand Am rotors are like 10mm spacers.
[This message has been edited by thesameguy (edited 01-20-2015).]
countach711
Report this Post01-20-2015 08:33 PM Click Here to See the Profile for countach711Click Here to visit countach711's HomePageSend a Private Message to countach711Edit/Delete MessageReply w/QuoteDirect Link to This Post
O.P. - looks great, I love 18's and found when I had some that the ride quality was just fine, not harsh at all. Two questions, though (the Fiero I had already had the 18's on it so I don't know any fitment issues firsthand) ; did you have to do rear coil-overs to get them to fit? And, do the fronts rub at all? I'm looking for rims again myself and thought 35 offset would be just about right.
[This message has been edited by countach711 (edited 01-20-2015).]
